throttle cable - JeepForum.com
post #1 of 2 Old 07-29-2011, 12:25 AM Thread Starter
Nashville4x4
throttle cable
Whenever i punch the gas, a little plastic piece keeping the throttle cable tight pops out of place. its an easy fix everytime it has happened, but i am curious should it be glued down or something? should i put like a ziptie on it or something?
Thanks Fellas,
Nashville
1998 ZJ | 5.2L v8 | trailer hitch d-ring shackle | future mods: new shoes and maybe some lights.
ɹəʌo əɯ dılɟ sıɥʇ pɐəɹ uɐɔ noʎ ɟı Nashville4x4
Nashville4x4 is offline
post #2 of 2 Old 07-29-2011, 02:28 AM
jnicewan
Sounds like the clip is either broken or worn out. I doubt glue will help since it has to move and pivot with the throttle cable. A zip tie may help you get by but it sounds like you need to replace the cable assy. If you come up with something to keep it in place just make sure it can't interfere with anything and possibly cause the cable to stick or hang the throttle open.
jnicewan is offline
Throttle Valve Cable Replacement (TV cable) orchimaxi ZJ Grand Cherokee Forum 11 03-27-2015 07:58 PM
throttle cable, and throttle body OfroadDominator ZJ Grand Cherokee Forum 4 01-23-2011 04:34 PM
Disconnecting throttle cable on 97 GC 5.2 V8 lunytnz ZJ Grand Cherokee Forum 1 05-13-2009 12:07 AM
throttle cable repair kit automan25 ZJ Grand Cherokee Forum 0 08-18-2003 09:48 PM
throttle cable automan25 ZJ Grand Cherokee Forum 2 01-03-2003 11:04 PM
