Throttle body questions... - JeepForum.com
post #1 of 5 Old 03-04-2013, 07:17 PM Thread Starter
BLarkin
Hey guys - I've been reading through all the threads on the injector swaps and intake swaps (4.0, btw) and wondering, what throttle body is everyone running? Stock zj? WJ? Aftermarket? I've read that the TB spacers really aren't worth the money, but have seen something about a 62mm (correct my numbers if I'm wrong) TB. I'm planning to do the 703 injector swap, 99+ intake swap, and possibly a header all at the same time, and would love to go ahead and change out the TB if necessary.
BLarkin is offline
post #2 of 5 Old 03-06-2013, 05:16 AM Thread Starter
BLarkin
Anyone?
BLarkin is offline
post #3 of 5 Old 03-06-2013, 07:12 AM
LordHobbit
If the motor is stock, I wouldn't worry too much about it, but if you are stroked, then yes, a larger TB would be beneficial.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #4 of 5 Old 03-06-2013, 12:08 PM
ajmorell
ajmorell's Avatar
I ran a stock one that was bored out to 60mm with a 99+ intake, header, cam, etc. Every little bit helps. I wouldn't waste several hundred $$ on a BBK, RE, HESCO or other name brand TB though, a stock one bored out achieves the same result.
ajmorell is offline
post #5 of 5 Old 03-06-2013, 01:13 PM Thread Starter
BLarkin
Stock ZJ, not stock WJ, right? This something you did yourself or send it out to a shop? I know I'm not going to pull too much power out of stock 4.0, but like you said, every bit helps.
BLarkin is offline
