Thinking Of Doing The V8 Tire Rod End On My 4.0 - JeepForum.com
post #1 of 33 Old 01-15-2012, 04:23 AM Thread Starter
torchd
2003 WJ
So I started doing research about how crappy and flimsy the tie rod ends are on the 4.0, how much beefier the tie rod ends are on the 5.2/5.9...
So I was able to compile a list of parts to use (tie rod, tie rod end and adjustable sleeve), but was wondering about the drag link bar. Where can I find a beefier drag link?
Then I came across this web site selling the beefier tie rod set up with a drag link, but the descrption says for 99-01 XJs, no mention of ZJs.. My question is, is the suspension on the 99-01 XJs the same as the ZJs?
Here is the website with the set up I am referring to.
http://www.knowwhere2jeep.com/steeri...ering-kit.html
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #2 of 33 Old 01-15-2012, 04:49 AM
bananaslug
Most people don't upgrade the steering until they up their tire size. What size are you running?
The V8s do have the beefier tie rod but the drag link is the same so you wouldn't be able to upgrade from the junk yard.
I can't answer your question but check out IRO Over the Knuckle steering if you are going to buy a whole new setup. That one looks most attractive to me.
bananaslug is offline
post #3 of 33 Old 01-15-2012, 04:59 AM Thread Starter
torchd
2003 WJ
I'm running 31s.. Most people replace it bc it is crappy from what I've read.
I don't have the experience in cutting and welding if you're talking about the flip over knuckle steering... is this what you're talking about? http://www.jeepforum.com/forum/f46/h...-flip-1182505/
2002 Trans Am
torchd is offline
post #4 of 33 Old 01-15-2012, 06:29 AM
Technohead
I've seen just about every aftermarket steering system get bent and have chewed through 4 Currie tie rods in the last 3 1/2 seasons. I've concluded that the best steering upgrade is a good spotter. Seriously.
If you must "upgrade" then don't use anything that requires reaming out the knuckles or uses heim joints. Once you ream out the knuckles then you can no longer swap in your buddies stock spare as a trail fix.
Go ahead and "upgrade" to the V8 ZJ steering if you want but carry a spare (the whole thing) on the trails. It will be cheaper in the long run.
-Eric
Technohead is offline
post #5 of 33 Old 01-15-2012, 06:57 AM Thread Starter
torchd
2003 WJ
I don't want to ream out the knuckle.
All I want to do is take a V8 tire rod and it's components and put it on my Jeep.
The V8 steering components are beefier and sturdier.
What's a good drag link and track bar (front and rear)
2002 Trans Am
torchd is offline
post #6 of 33 Old 01-15-2012, 01:58 PM
TallyZJ
Originally Posted by torchd View Post
That is the flip version that I did using a right hand drive drag link. Works great but is was time consuming and needed quite a few tools. If money wasn't an option I would have went with an IRO or U-Turn system.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #7 of 33 Old 01-15-2012, 02:01 PM
TallyZJ
All you need is the V8 tie rod, a tie rod end and adjuster sleeve, not the drag link (right side outer tie rod end actually). The drag link is the same as all models and is solid bar stock.
I like the IRO front and rear HD track bars.
TallyZJ is offline
post #8 of 33 Old 01-15-2012, 02:18 PM
bananaslug
Email kolak@aol.com He has very competitive pricing on the JKS track bars and can explain the difference between that and the IRO. I just ordered the front from him.
post #9 of 33 Old 01-15-2012, 02:40 PM Thread Starter
torchd
2003 WJ
Originally Posted by TallyZJ
All you need is the V8 tie rod, not the drag link. The drag link is the same as all models and is solid bar stock.
Thanks TallyZJ for responding! I was really impressed with your work!! I just don't have the experience to do what you did.
So I got a list of Moog parts to do the V8 tie rod swap. Tie rod, tie rod end and the adjustable sleeve.
I figured I would replace the drag link and track bar while I was there. TallyZJ do you have a preference in a drag link?
Newb question here... What does HD stand for when referring to track bars?
2002 Trans Am
torchd is offline
post #10 of 33 Old 01-15-2012, 03:08 PM Thread Starter
torchd
2003 WJ
One more thing for Tally..
What is the best way to take the old TRE off and make it match up with the new TRE so that steering isn't too bad before getting an alignment? Don't you count the threads on the old TRE and turn new TRE out just as many threads counted to match it as close as possible?
Thanks
2002 Trans Am
torchd is offline
post #11 of 33 Old 01-15-2012, 04:01 PM
TallyZJ
Not as difficult as it might seem. Drilling the knuckle was the most important part to get right. It was even very easy though. The rest is mostly just cutting off some parts and installing the new stuff.
Not really. I like Moog stuff but any major store brand part should be sufficient. I purchased Car Quest brand parts on mine. Its solid stock so its pretty tough.
Heavy Duty. Nice fat thick tubing that is very tough.
Thanks
Better to make an actual measurement instead of counting threads. The old tie rod end will be worn and thread count may not put you back where it was. Measure its length and make the new one the same length.
Still, when you are done with the front end work, get an alignment.
Also, I would replace the steering damper while you are replacing parts under there. its cheap and is a little insurance against wobble and road feel.
I also want to make a little technical note here. What you are calling the drag link is actually the right outer tie rod end. There is no real drag link on this style steering system.
TallyZJ is offline
post #12 of 33 Old 01-15-2012, 04:25 PM Thread Starter
torchd
2003 WJ
Yeah during the TRE swap I was going to put on a new steering stabilizer while I was there. And yes after the TRE swap I was going to take the Jeep in for an alignment.
What are some good alignment specs for the ZJ with the V8 TRE as well as a 2" BB lift???
Would this be good for the Jeep? The "drag link" and TRE are both 1" solid steel for $150? http://www.knowwhere2jeep.com/steeri...ering-kit.html
It says that it is for 99-01 XJs, but is the XJs front suspension the same as ZJs front suspension?
Thanks Tallky for your help!!
2002 Trans Am
torchd is offline
post #13 of 33 Old 01-15-2012, 04:59 PM
TallyZJ
Would this be good for the Jeep? The "drag link" and TRE are both 1" solid steel for $150? http://www.knowwhere2jeep.com/steering/crown-heavy-duty-steering-kit.html
The XJ is the same as the ZJ front end parts.
Alignment specs? Just have them get it as close to factory as they can. With a 2" budget lift you won't be that far off.
TallyZJ is offline
post #14 of 33 Old 01-15-2012, 06:43 PM Thread Starter
torchd
2003 WJ
Did you click on the link 2 posts above this?
Would it be worth it to buy those components from that link, or buy the parts individualy?
2002 Trans Am
torchd is offline
post #15 of 33 Old 01-15-2012, 07:07 PM
TallyZJ
That is a decent price for two pieces. However, I was unsure if the tie rod is the same beefy tie rod that comes with the V8 ZJ? If so, not too bad of price.
I got my tie rod from a salvage yard V8 ZJ and added a brand new tie rod end to it.
I paid like $15.00 for the tie rod and about $25 for a new tie rod end.
The right outer tie rod "drag link" (from the Right Hand Drive Cherokee) is what cost me $140.00.
TallyZJ is offline
thinking about a zj wantajeep631 ZJ Grand Cherokee Forum 8 08-04-2011 05:21 AM
thinking about a zj gawe22 ZJ Grand Cherokee Forum 24 03-09-2011 10:50 PM
Thinking about a new WJ..Got a few ?'s MyZJ98 ZJ Grand Cherokee Forum 14 08-18-2009 11:45 AM
thinking about... Arkansas_WJ ZJ Grand Cherokee Forum 13 01-03-2007 12:48 PM
Worst times of thinking "what WAS I thinking?!" ItsJustJeep ZJ Grand Cherokee Forum 6 12-10-2004 10:17 PM
