Thinking about upgrading to long arms - JeepForum.com
post #1 of 4 Old 10-31-2013, 11:02 AM Thread Starter
Dubfire98
So while I've been upgrading everything that breaks or is worn out on my zj here recently I've noticed the need for new rear CA's. Getting alot of noise and axle wrap.I'm currently running a 4" or 4.5" lift (bought it lifted). And instead of buying new short arms I was thinking of going ahead and swapping to long arms. Can I just buy the long arm hardware instead of the full kit and use my current springs, end links, track bar, etc?
TN JEEPER
Dubfire98 is offline
post #2 of 4 Old 10-31-2013, 11:04 AM
David97
IRO, Clayton, and I think Rubicon Express all sell long arm upgrade kits. Might be others too.
David97 is offline
post #3 of 4 Old 10-31-2013, 11:11 AM
WhiteOut
WhiteOut's Avatar
Out of those 3, Clayton is the only real upgrade.
Sent from AutoGuide.com App
WhiteOut is offline
post #4 of 4 Old 11-01-2013, 08:34 AM
Timo_90xj
Timo_90xj's Avatar
Clayton is the best of those, but it does rob quite a bit of clearance from under the uniframe rails. Too bad they don't make a true front 3-link + panhard kit for the ZJs, like they do for the XJs. Way better than the so-called "3-link" that is actually radius arms with only a single upper on one arm. The rear lowers could use quite a bit more triangulation on the Clayton kit for added side stability and better axle path, but it anyways is a a 4- link without a trackbar (which is a good thing) and as that a much better system than ie. IRO or RE.
Rubicon express is a radius arm front and 4-link + panhard bar rear long arm kit. So is the IRO kit, but IROs single front upper arm thingy is kind of a joke. I would not trust it with a single 10mm/ 3/8" bolt with the weird adjustment system. Rear setup is pretty much the same as RE (4-link + panhard). Installation is a bit more straightforward on the IRO kit.
If I were to choose from those, I'd get the Clayton kit. Even though it does rob some belly clearance, it's the best of those three. With some DIY high- clearance mounts on the belly, it would be even better.
***Under construction***
Timo_90xj is offline
