Thinking about a transfer case swap - JeepForum.com
post #1 of 10 Old 05-07-2009, 11:10 AM Thread Starter
kmk108
Summer is getting close and am thinking of things to do. I don't think my transfer case is working because I don't have Neutral or 4wd low working. I am thinking about doing a 249>242 swap. My question is, which ones should I look at? Will the ones from a 4.0l work? what about the ones from a wj?
30 BFG A/T, Flowmaster Super40, Alpine head unit, Alpine amp, Rockford speakers, Sony subs, cobra cb
White Jeep Club Member #108
2009 FA CUP CHAMPIONS
CAREFREE, WHEREVER WE MAY BE
WE ARE THE FAMOUS CFC
AND WE DON'T GIVE A F@#K
WHOEVER YOU MAY BE
CUZ WE ARE THE FAMOUS CFC
kmk108 is offline
post #2 of 10 Old 05-07-2009, 11:29 AM
CLNinja
CLNinja's Avatar
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #3 of 10 Old 05-07-2009, 01:09 PM
nashmd454
nashmd454's Avatar
Love that pic CLNinja....ohhhh sooo true. Mr kmk108....please check out the faq (FREQUENTLY asked questions) section on here. There are many topics on benefits and so forth and who likes what t case. I myself did a 242 swap just so I wouldn't have to ever worry about the vc (viscous coupler) going out on the 249. I would suggest that you get the same model year...but please check out the faq's.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #4 of 10 Old 05-07-2009, 01:13 PM
Greeeeenberg
Here before you get flamed anymore. Ask questions in there keep it going for others
http://www.jeepforum.com/forum/f13/t-case-swap-display-unit-672768/
97 ZJ Orvis 5.2 108K.
Member #1
Greeeeenberg is offline
post #5 of 10 Old 05-07-2009, 02:09 PM Thread Starter
kmk108
ok. flaming can cease. I always forget to do check the FAQ. new question. I read something about taking the driveshaft from the 242 and making sure the slip yoke is right. If i did a slip yoke eliminator at the same time, will that solve the slip yoke and driveshaft issue?
WHOEVER YOU MAY BE
kmk108 is offline
post #6 of 10 Old 05-07-2009, 02:14 PM
zjilla
u sure its just not engaging? try checking the linkage. Although the swap isnt a bad thing....
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #7 of 10 Old 05-07-2009, 02:19 PM Thread Starter
kmk108
I'm not sure what's wrong with it. Ever since i put my lift in, it hasn't worked. I can pull the selector all the way down and all the way up with nothing happening. Im wondering if the link to the transfer case is broken or disconnected. But I want to do the swap anyway.
WHOEVER YOU MAY BE
kmk108 is offline
post #8 of 10 Old 05-07-2009, 03:27 PM
nashmd454
nashmd454's Avatar
I wasn't flaming you Bro...though I did like the pic. I saw your post count and assumed that you may not have known about the faq section...I wasn't flaming you.
As far as the drive shaft issue...when doing a swap....lets say from a 249 to a 242...then you will need to swap out input/output (some people look at them differently) shaft from the 249 to the 242...that way you will not have to shorten the ds. Also ensure both have the correct spline count. Also I would have a look at the linkage...but if swapping then no need to.
post #9 of 10 Old 05-07-2009, 04:01 PM
CLNinja
CLNinja's Avatar
look at your linkage... guarantee something came loose in the linkage ( very easy fix ) if your able to very easily move your shifter forward and back without and resistance
Matt
CLNinja is offline
post #10 of 10 Old 05-07-2009, 04:24 PM Thread Starter
kmk108
No problems. I didn't want to turn the thread into a noob bashing lol. basically I'm learning about the way my jeep works as things break lol. I'm pretty stupid when I start, but I learn easy. So doing the SYE and driveshaft change when I do the transfer case swap won't matter?
WHOEVER YOU MAY BE
kmk108 is offline
transfer case swap lx2gt ZJ Grand Cherokee Forum 1 11-07-2009 01:55 PM
transfer case swap help ttavenieriii ZJ Grand Cherokee Forum 4 01-29-2009 07:13 PM
Thinking about a T-case swap, 247 to... what should I be on the look out for? Soft 8 ZJ Grand Cherokee Forum 15 11-20-2006 02:53 PM
transfer case swap jeep946 ZJ Grand Cherokee Forum 2 03-26-2006 11:11 AM
'94 - '95 249 - 242 Transfer Case Swap gcjeeper ZJ Grand Cherokee Forum 5 08-22-2005 11:12 PM
