Things to Look for Buying a 2002-2004 WJ - JeepForum.com
post #1 of 5 Old 10-01-2009, 01:01 PM Thread Starter
atchudy
I'm looking at a couple 2002-2004 Limited or Overland in NJ this weekend, with 60-80k Miles.
What should I look for when driving and inspecting the car?
atchudy is offline
post #2 of 5 Old 10-01-2009, 01:10 PM
LordHobbit
Make sure it runs. You'll want to shift through all transfer case selections, 4wd full, part, lo and make sure it shifts nicely. Make tight figure 8s and check for binding, anything binding.
Then the usual, oil or coolant in the exhaust, tires, dings, check the undercarriage in case someone hit a big rock or something ...
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #3 of 5 Old 10-01-2009, 01:32 PM
cmonson
check for hvac codes relating to the blend doors which will be a problem unless someone else dealed with them.
do some tight figure 8s and check for binding.
smell the tranny fluid to see if it s burnt.
In all truth, if you do not feel confident inspecting a car on your own, go to a Jeep dealer and pay them to do an inspection. Well worth the money if you are spending $8K+ on a car.
cmonson is offline
post #4 of 5 Old 10-01-2009, 03:23 PM
volvite
Best option, take it too a Jeep dealership. I did before I bought mine, and it cost 50 bucks for a used car pre inspection. They advised me of a new belt and the hood lift shocks, both of which I already knew about, but it confirmed what I had decided.
volvite is offline
post #5 of 5 Old 10-01-2009, 03:39 PM
malibubts
If it's an 02 you might want to check out the brake calipers. Jeep put front calipers that warped the rotors on until mid 02. Here is some info on WJ Jeeps about the situation.
Eric - '02 Laredo Grand Cherokee
malibubts is offline
Buying a GC. Things to look for/ Avoid? Curtis Doran WK Grand Cherokee & XK Commander Forum 9 06-30-2009 05:23 AM
4.7L HO 2002 vs 2003, 2004 NEED HELP!! cmoodie ZJ Grand Cherokee Forum 7 11-15-2008 09:42 AM
Things to look for when buying a JGC TeeJeep ZJ Grand Cherokee Forum 1 05-18-2007 07:07 PM
buying advice on a 2002-2004 trigger0 ZJ Grand Cherokee Forum 13 03-01-2007 08:44 PM
Buying a WJ...2002 or 2004 mferraro76 ZJ Grand Cherokee Forum 3 10-15-2006 04:54 PM
