These compression numbers ok ?? - JeepForum.com
post #1 of 3 Old 07-17-2011, 12:20 AM Thread Starter
Candymancan
Ok i did compression test, as i've never done it b4 on my 5.9 and these were my results. With a warm motor i tested it dry and then squirted oil in there.
#1. 160, with oil 167
#2. 150, with oil 155
#3. 164, with oil 167
#4. 165, with oil 168
#5. 163, with oil 169
#6. 163, with oil 168
#7. 164, with oil 166
#8. 160, with oil 165
Is this ok ? Number 2 seems low, but it didnt Jump anymore then the others did with oil in it. I checked it twice to make sure. I dunno number 2 has me a little worried because its like 10-15psi lower then the others.
Btw i disconnected the ignition oil, and move the wires away from the coil itself. I didnt have the engine on WOT tho.. read that after i did this.. Is this ok ?
One thing i noticed was when reading #2 which is the one closest to the ignition coil the engine was sputtering and shaking and the light in the engine bay was flashing.. I have no idea why it did that on #2 and not the rest. Could it be because the coil is closest to #2 ? Should i try it again and maybe remove the coil from the engine all together, cause it acted like it was actually trying to start
Candymancan is offline
post #2 of 3 Old 07-17-2011, 03:45 AM
TheHalfWit
Its within the acceptable range, what I did though was yank the fuel pump relay since that's much simpler. All you need to do is prevent it from starting. WOT should prevent it from starting since its gas pedal is connected to the throttle body, but unless you have an assistant you might not be able to crank it and watch the gauge while holding the throttle open.
Acceptable range is usually 10%, so that isn't outside of the specs.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #3 of 3 Old 07-17-2011, 01:53 PM
jnicewan
Those numbers look good to me, I personnally like to see no more than 10% difference as mentioned above, but even 20% would be considered ok. The reason for cranking at WOT is to allow as much potential air into the cylinders as possible. Cranking at WOT also disables the fuel injectors via PCM, it is a "clear flood" strategy. I usually just unplug the coil just so ign sparks dont fly around.
jnicewan is offline
5.2L with no compression on 4 & 6 Dukota ZJ Grand Cherokee Forum 10 01-11-2011 09:00 AM
Compression Help Please jdc224 ZJ Grand Cherokee Forum 8 09-11-2010 01:57 AM
Compression numbers Justin00LTD ZJ Grand Cherokee Forum 1 12-31-2008 11:09 AM
Good Compression numbers? sk8142 ZJ Grand Cherokee Forum 11 11-17-2007 09:32 AM
ZJ 4.0L Compression ShadMan ZJ Grand Cherokee Forum 1 09-04-2004 07:54 AM
