Are these compression numbers on my 5.9 ok ? - JeepForum.com
post #1 of 20 Old 05-02-2013, 05:22 PM Thread Starter
Candymancan
I havent ran a compression check in 2 years and the first time i did it wrong i didnt step on the throttle to open the valve body up..
So per what a few said to do since i fixed my intake manifold i did another compression check.. Engine was hot, Took all the plugs out disconnected the ignition coil and ran the check with throttle open all the way and checked with oil as well.. I should note i forgot to unplug the fuel pump so i think 1-3-5-7 are a tad lower then the other side because they were washed with gas
Here are the numbers first number is dry second is oil.
#2. 173-175
#4. 185-188
#6. 185-188
#8. 185-186
#1. 175-175
#3. 175-179
#5. 179-180
#7. 170-173.
They are all within 10% of eachother (well the 185's and 170's are close) and they dont really go up with oil in them.. But the compression just seems really high.. Perhaps my engine is really gummed up ?? or my engine is in very good health... or both lol. I dont know what the norm is suppose to be
Candymancan is offline
post #2 of 20 Old 05-02-2013, 06:10 PM
StrateLOSS
compression tests are accurate it showing compression psi relative to the cylinder next to it.
meaning the "185" number may or may not really be 185, it could be 160 with a different gauge or 200 with another gauge.
everything is close enough that I'd be happy with those results.
Sent from AutoGuide.com Free App
StrateLOSS is offline
post #3 of 20 Old 05-02-2013, 09:20 PM
MN59ZJ
What??? If you zero out the gauge for each cylinder check, you should be looking at the exact number for each cylinder.
#2. 173-175
#4. 185-188
#6. 185-188
#8. 185-186
#1. 175-175
#3. 175-179
#5. 179-180
#7. 170-173.
Cylinder pressure should be between 120-150PSI with no more than a 20% variation of each other. Your's are high which may indicate carbon deposits in the cylinders.
MN59ZJ is offline
post #4 of 20 Old 05-02-2013, 10:24 PM
StrateLOSS
ok? what's your point ?
post #5 of 20 Old 05-02-2013, 11:52 PM Thread Starter
Candymancan
120-150 are you sure about that ? I've seen alot of 5.9's on google with higher compression then that.. 120 seems really low like rebuild time low.
I know mine are high and i probly do have carbon specially since ive been burning oil for a long time and just finished my plenum.. but still
post #6 of 20 Old 05-03-2013, 12:36 AM
jnicewan
Yep the spec is 120-150 PSI. And that is measured with engine a normal operating temp. Most of the time the pressure specs would measure lower with colder engine temps.
I would say your guage is either inaccurate or you have carbon build up or something else causing elevated readings
jnicewan is offline
post #7 of 20 Old 05-03-2013, 12:39 AM Thread Starter
Candymancan
probly carbon. when i saw my intake valves they were pretty nasty.. my engine still pings even after the intake was fixed and i have a catch can.. gauge is $30 gauge by actron .. probly not the best either but still.
soo what should i do then ? what will the higher compression do to the engine ?
post #8 of 20 Old 05-03-2013, 12:53 AM
jnicewan
Yea, its probably not the guage, its not usual for a guage to be inaccurate on the high side. Higher than normal compression is probably not going to hurt anything unless the engine is pinging a lot. The spark knock itself can cause damage. Since its pretty cheap and easy I would attempt to de-carbon the engine, maybe even double up on the cleaning.
jnicewan is offline
post #9 of 20 Old 05-03-2013, 01:03 AM
MN59ZJ
That the advice you gave is only true if you are doing the check wrong.
MN59ZJ is offline
post #10 of 20 Old 05-03-2013, 01:06 AM
MN59ZJ
Yup. I just rebuilt mine & I have ~130 across all 8 cylinders. Rebuild time is when they drop below 100, which is 120 - 20%.
MN59ZJ is offline
post #11 of 20 Old 05-03-2013, 11:44 AM
StrateLOSS
please explain
post #12 of 20 Old 05-03-2013, 11:59 AM
MN59ZJ
please explain
This is simply wrong (or at least poorly worded) and everything else that followed was based on this statement.
MN59ZJ is offline
post #13 of 20 Old 05-03-2013, 12:16 PM
StrateLOSS
you did not explain it pal kudos to you, you'll now be ignored.
post #14 of 20 Old 05-03-2013, 02:37 PM
PolkaPower
I guess it's a str8loss!
PolkaPower is offline
post #15 of 20 Old 05-03-2013, 03:59 PM Thread Starter
Candymancan
Question mn59 when you neasured yours did you stwp on the gas pedal to open the throttle up.. Because if i dont do that my results are more in the 148-160 range with the throttle open they go up 20 psi.. And how many cranks is too many.. I cranked mine till the guague stopped going up which was probly 5-6 per cylinder.. Mine were with a burning hot engine not cold. I dunno why you said cold
And what are good nunberz for a 4.0 i think ill go ahead and check that engine too it just passed 200k and has never been checked before
