Thermostat stuck shut? - JeepForum.com
post #1 of 7 Old 02-28-2004, 11:03 PM Thread Starter
Choff
How does one tell if the thermostat it stuck shut? There's been a lot of steam coming off of my engine (93 4.0L) lately, but it's really wet here (lots of "lakes" from melting snow)... well, after driving it long enough to get totally warm, I checked the radiator cap, not hot... opened it, no pressure and the antifreeze wasn't more than lukewarm. WHen I start the thing after it's been sitting for a while a big old cloud of steam comes off then it tapers back. This could be from water dripping down on something hot, but it comes rolling off as soon as the engine fires (fan blowing it around?)
The temp gauge reads abotu 210 when it's warmed up, which is where it's always been. The heater works.
Is the temp sensor in the engine or the radiator?
THanks
Chris
Choff is offline
post #2 of 7 Old 02-29-2004, 08:19 AM
Wondy
Its prob not the thermostat because in my 94 4.0 my thermostat go stuck shut and the engine ran at about 240-260 and i had no heater. It costs about 7 bucks for the thermostat and gasket.
Wondy is offline
post #3 of 7 Old 03-01-2004, 10:13 AM
94ZZJJ
Mine stuck shut a little while ago(v8). After a minute of idling the top rad hose became hard while cold and a little while later all the hoses started to leak past the clamps and the bulkheads for the atf cooler in the rad started leaking and made a puddy. I fixed it w/ a new stat and just put a new 3row hd all metal rad in it
On a v8 there are 2 sensors. One for the gauge and one for the ecu. The ecu sensor is next to the tsat housing and chiltons says the gauge is on the left side of the engine(?). I replaced the sensor by the stat thinking it was for the gauge and it wasn't.
Make sure you still have coolant
94ZZJJ is offline
post #4 of 7 Old 03-01-2004, 11:27 AM Thread Starter
Choff
Yeah, I don't think it's the thermostat. The heater works fine and it doesn't overheat. There is antifreeze...
I hope the steam is just from all the water around here. As many nasty tricks as that thing has been playing lately I am tired of it.
Any idea how to adjust the idle (if possible)? I replaced the O2 sensor and it runs a lot better... but now it idles at like 1700 rpms, which makes the tires squeak when you put it in gear...
Thanks
Chris
Choff is offline
post #5 of 7 Old 03-02-2004, 08:53 PM
Saleen4971
thats probly yout IAC. 60$ i think is retail price for one. two torx head screws (#25? i think?) i jsut had to replace mine at almsot 126k
1998 5.9 Limited
ET: 14.3@94MPH
Engine/Trans
- Full Kolak Exhaust (ML's FM70) - FIPK2 - APS 52mm TB - MSD Blaster SS - A3923's - Magnecor's - MP ECU - 180 robertshaw t-stat - Relocated IAT - E.H. M1 - B&M Trans Cooler
Susupension/Brakes
- Addco 1.25" Military front & 7/8" rear sways - Edelbrock IAS shocks - OME S.S - Stilens Front & Rear
Coming Soon :
Level10 Stage 3 46RE - WJ knuckle conversion
Saleen4971 is offline
post #6 of 7 Old 03-03-2004, 06:22 AM Thread Starter
Choff
What's the long name for that unit and where's it located? In the throttle body?
Thanks!
Chris
Choff is offline
post #7 of 7 Old 03-11-2004, 02:54 PM
KyleM
Thanks!
Chris
Idle air control valve (or motor). Yes, it is located on the side of the throttle body.
KyleM is offline
99' Grand Cherokee Hood stuck shut...need some advice pwrtrip95z WJ Grand Cherokee Forum 20 09-25-2016 12:00 PM
My VIC wont shut off thingtwo235 ZJ Grand Cherokee Forum 11 11-24-2012 07:33 AM
WJ door getting stuck when locked shut mx416 ZJ Grand Cherokee Forum 3 06-14-2009 08:42 PM
VIC Won't Shut Off _Kyle_ ZJ Grand Cherokee Forum 4 11-11-2008 01:38 PM
AC won't shut off!!! WTF armed247 ZJ Grand Cherokee Forum 15 05-20-2008 09:58 PM
