Thermostat Location - JeepForum.com
post #1 of 16 Old 01-15-2011, 11:28 AM Thread Starter
TewSmooth18
Thermostat Location
Can somebody tell me where the thermostat location is on a 97 grand cherokee with a V8 5.2l? I've tried google searching it and the pictures that I have been able to pull up are showing the location but when I look at my engine i'm not seeing what is being showed in the pictures. (Pictures are showing it being at the front of the engine under the pulleys). What i'm seeing is a water outlet coming from the top of the engine (with radiator hose going to top right side of radiator if looking from the front of the jeep to the back of the jeep) but i'm not sure if that is actually where it's located or not.
A picture would be helpful as well.
Thanks in advance
TewSmooth18 is offline
post #2 of 16 Old 01-15-2011, 04:59 PM
BongCAT
2005 WK
Sorry no pics...wish I had seen this earlier today...just got finished dropping in a new rad.
The thermostat is located in the engine beneath the top radiator hose flange. Two bolts and there it is.
BongCAT is offline
post #3 of 16 Old 01-15-2011, 09:41 PM
bigbossd1030
Just follow your top radiator hose to your engine.
The part that the hose clamps to is the thermostat housing, under this is where your thermostat is.
Just remove your hose (there will be some coolant that will leak out of this hose when disconnected) and you will see the thermostat in the housing, then remove the two bolts and pull the housing off. Take note as to how the gasket sits, I cant remember is it goes Engine, gasket, thermostat, housing or... engine, thermostat, gasket, housing. It makes a difference, I did mine backwards and it leaked. Oh and RTV sealant is your friend. Make sure you give it the full 24 hours to dry. Oh and people will say not to tighten it too much, thats what the gasket is for.... WRONG! Tighten it as much as you can, I did mine not too tight and it leaked, I had to tighten it till the bolts wouldn't turn anymore.
Well, good luck
Oh and if you havent already, you may need to change the clamps with some new ones, More adjustable ones, Mine didnt seal the hose on the housing tight enough, so I had to replace with some new ones.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 16 Old 01-16-2011, 12:29 AM
tonymartin
yep, as bigboss said, the order is engine, t-stat, gasket, housing. Use a touch of RTV on the lower rim of the t-stat to get a proper seal, but not too much as you may clog the t-stat. Then just bolt it back up. It does help to remove the alternator too as this gets in the way BIG time.
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
post #5 of 16 Old 01-16-2011, 10:32 AM
tcar
You NEED, NEED to go to your auto parts store and pick up a Haynes Manual. Pictues and everything.
tcar is offline
post #6 of 16 Old 01-16-2011, 06:08 PM Thread Starter
TewSmooth18
I've got a Chiltons but obviously the thing sucks because the pictures that are showing in it are of the other style where the thermostat housing is bolted to the front of the engine and not the top of the engine like mine. I've looked and it looks like it might be a pain in the *** to change it without removing the altenator but i'm not going to remove it, i'll just work with it
post #7 of 16 Old 01-17-2011, 01:01 AM
Dustmuffins
Just use some antiseize, or else you'll end up like me:
Dustmuffins is offline
post #8 of 16 Old 01-17-2011, 06:36 PM Thread Starter
TewSmooth18
I got it changed, and you were right. i did have to remove the altenator. damn near impossible to do it without removing it. Thanks for the help!
post #9 of 16 Old 01-17-2011, 08:00 PM
Yardman Harry
O
Yardman Harry's Avatar
Thats poor advice, no offense. But tighten to spec and it works fine. Tighten too much, crack the manifold, purchase new manifold.
Torque specs for t-stat housing is 200 in-lbs for the 5.2 engine.
Yard
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #10 of 16 Old 01-17-2011, 08:14 PM
LouC
2007 WK
Agree on the above point, if you can't get it to seal by making them a bit past snug, then you didn't clean off all the old sealant, or the thermo housing may be corroded to the point that it does not seal. DO NOT overtighten those small bolts or you will be sorry. I just did a water pump on my old ZJ and I had no problem getting out the old bolts. Then I cleaned ALL the old sealer off and used Permatex gasket sealer (I have the marine version of this and it works great) on the gasket and the bolts, that keeps the bolts from seizing in place, the sealer seals out corrosion. It does not harden up either, I use the OMC (Evinrude/Johnson) marine version of the Permatex gasket sealer in salt water applications and it works great, the bolts come right out.
LouC is offline
post #11 of 16 Old 01-17-2011, 08:42 PM
tonymartin
Glad you got it done OP. Welcome to the world of wrenching!
post #12 of 16 Old 01-17-2011, 09:56 PM
bigbossd1030
Yard
I dont have a torque wrench so I have to use my guess wrench, and when I tightend it up to just past snug, it leaked 3 times, once I tightend it as much as I could, stopped the leak and no problems. If you can crack your manifold, then you should have looked at the treads or made sure you didnt cross thread it, plus just using a socket wrench, without a stirker bar, it may be hard to crack the manifold. anyway, I only gave advice from what I did and from what worked.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #13 of 16 Old 01-17-2011, 10:01 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
200"lbs is about 15ftlbs, about 1/2-2/3 turn past snug.
Get a torque wrench and stop giving damaging advice.
Your intake is aluminum, over torquing will crack it.
ratmonkey is offline
post #14 of 16 Old 01-17-2011, 10:05 PM
bigbossd1030
Well I have never had to won one, beacues I am not a complete dumba$$ and cracking all the stuff on my jeep. So I will continue to use my good ol guesswrench that has never failed me once.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #15 of 16 Old 01-18-2011, 11:30 AM
tcar
Never WON what????
It's actually about 17 ft-lbs.
Good luck on guessing. And winning.
tcar is offline
New thermostat? Shelbyzz ZJ Grand Cherokee Forum 10 09-02-2008 05:21 PM
Where is Thermostat on 98 GC? BorisMD ZJ Grand Cherokee Forum 3 12-09-2007 08:18 PM
WJ 4.0L thermostat indept ZJ Grand Cherokee Forum 1 11-10-2007 10:17 PM
could it be my thermostat? askoop ZJ Grand Cherokee Forum 19 08-14-2007 09:40 PM
'95 JGC and thermostat.... Nancy1964 ZJ Grand Cherokee Forum 6 09-30-2005 11:40 AM
