Thermostat issue - JeepForum.com
post #1 of 8 Old 06-02-2013, 09:53 AM Thread Starter
jchambers224
Thermostat issue
We have had 3 different thermostats in our 95 GC and cant get any of them to run anywere close to the 195-210 mark. Whats the deal?
jchambers224 is offline
post #2 of 8 Old 06-02-2013, 10:22 AM
ZeeJay1997
try changing the coolant temp sensor on top of and at the back of the head, or first just try cleaning and reseating the connector
ZeeJay1997 is offline
post #3 of 8 Old 06-02-2013, 10:52 AM
dnuccio
the gauge is probably off. when my gauge reads 210, an infrared thermometer shot at the cylinder head reads 165
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 8 Old 06-02-2013, 10:53 AM
JasonStebbins
Why are you replacing the thermostat? Are you experiencing overheating issues? The stock thermostat is 195 degrees. Your 4.0L should run at 210 all day long.
Poop
JasonStebbins is offline
post #5 of 8 Old 06-02-2013, 07:49 PM
StPaul59
Are you using one of those 'Fail Safe' thermostats? They are junk.
StPaul59 is offline
post #6 of 8 Old 06-02-2013, 10:42 PM
zjosh93
Agree that FailSafe are crap, so are the Robert Shaw hi flow thermostats, used to be the best but I had two fall apart in my engines.
As stated above we could use more info. Are you over heating, is the gauge doing weird things, anything else going on? Bad fan clutch? Any other engine issues?
zjosh93 is online now
post #7 of 8 Old 06-03-2013, 11:03 AM
Dubfire98
I had a similar problem on my 5.2l. Temp kept going up and down randomly. even spiked once then suddenly fell back down to 210. Needless to say i tried the failsafe therm, JUNK! They actually lock open once they hit they designed temp and they STAY open until replaced. My problem turned out to be the fan clutch. The resistance test didnt help me any cause i still had what seemed to be a good amount of pull on it, but sure enough it was bad. Today going with a new OEM thermostat, and just a quick compression test to make sure my head gasket is still good. Coolant is looking a lil cloudy, but not using/leaking oil or coolant, no coolant mixed with oil, not burning white smoke, but still weird colored coolant.
Dubfire98 is offline
post #8 of 8 Old 06-04-2013, 06:49 PM Thread Starter
jchambers224
Problem solved! It was the coolant temperature switch. We are having problems with it smoking when it is sitting at an idle. When we take off again it smokes. Noticed it wasnt runnimg at approp temp so thought it might be that. Still smoking though after this was fixed. I have another thread regarding this matter now.
