@MEinSoCal
Go check this link
here.
Originally Posted by wjjeeps.com
Eight climate control lamps are soldered onto the internal circuit board of the Automatic Zone Control assembly. These are unlikely to burn out for many years, but some owners have wanted to color the bulbs. To remove the AZC unit, the radio bezel and the lower bezel assembly must be removed. Both bezels are pried out using a flat hard plastic blade tool (see ashtray lamp section above). The AZC unit is held in place by 4 Phillips screws. After removing the screws slide the unit out and unplug the two wiring harnesses in the rear. To open the unit, remove the two smaller knobs in front by pulling them straight out. Then remove the 4 rear screws with a Torx T-20 screwdriver to separate the front plate.
HTH.
Although it doesn't sound too good on the other hand if multiple bulbs
fail at the very same time... Ya might wanna look for a spare already
just in case...
EDIT:
The non-AZC mounts to the same bracket positions. The instructions
on how to start and remove the center console bezel thingy is also
on the website I posted above.
