Thank you speed bump i did not see on a pitch black road - JeepForum.com
post #1 of 12 Old 07-12-2013, 11:41 PM Thread Starter
buttersjeep90
Seeing as i hit a speed bumper doing about 35 miles an hour i now need to replace all of this. I have check everything out and these things are now messed up. Still drives fine on the street but once i get high way speeds it shakes violently.
front sway bar bushings
front sway bar links
upper and lower ball joints on both sides
and the computer tie rod steering assembly
Everything from autozone is just to much money and advance always sells you the wrong part(s), and some parts both stores have to be order or I gotta drive to quam to a store that has them. So I went on quadratec.com and found everything and with shipping it all comes to 354.87. what are you's guys thoughts? I haven't ordered anything yet.
I know all that stuff is maintanence. I just wasn't planning on having to spend that this coming week. Any suggestions on each places or if that sounds about right for those parts from that side.
buttersjeep90 is offline
post #2 of 12 Old 07-12-2013, 11:44 PM
jnicewan
Not going to price compare for you but check out rockauto
jnicewan is offline
post #3 of 12 Old 07-12-2013, 11:51 PM Thread Starter
buttersjeep90
I'll check it out
post #4 of 12 Old 07-13-2013, 02:13 AM
zjilla
http://www.jeepforum.com/forum/f13/r...essed-1547990/ replace ur whole steering. Get currie. About the same price
Sent from my GT-N7000 using JeepForum
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #5 of 12 Old 07-13-2013, 02:57 AM
970001zj
it needed it anyway
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #6 of 12 Old 07-13-2013, 07:12 AM
eagsc7
1994 ZJ
Sounds to me like it's time to get the lift done. I know that some lift kits have you replacing these items, so it seems to be "the time"
eagsc7 is offline
post #7 of 12 Old 07-13-2013, 09:33 AM
Jeeples
Jeeples's Avatar
For about $100 more than Q-tec you could go with the JCR one ton setup.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #8 of 12 Old 07-13-2013, 09:39 AM
austentatious
You sure it didnt just knock a wheel weight off one of your wheels? I would go have your tires balanced before you drop all that money.
O|||||||O
|ProComp|Rokmen|Zone|MetalCloak|RockHard|Mastercra ft|TomWoods|Novak|TenFactory|Synergy|
austentatious is offline
post #9 of 12 Old 07-13-2013, 10:44 AM
96zedjay
Or a busted belt in the tire.
96zedjay is offline
post #10 of 12 Old 07-14-2013, 11:29 PM Thread Starter
buttersjeep90
i'm sure, i put the front end in the air and took the wheels off. those are fine. then i started from the drivers side and worked my way over to the passenger side and my tie rods have alot of play in them and my sway bar bushings and end links are bent and bushings are bad. shes got 197k and counting so i'm gonna keep her going. i don't want to lift it seeing as i might be getting rid of it next spring. i atleast want one more winter with my zj. and plus i dont know if or when the tie rods and sway bar stuff was ever done, so better safe than sorry.
post #11 of 12 Old 07-14-2013, 11:53 PM
dnuccio
your stuff mustve been pretty close to wiped out already, because ive hit speed bumps at 40+ with no ill effects
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #12 of 12 Old 07-15-2013, 07:16 AM
KJK
He was doomed as soon as the "computer tie rod steering assembly" took a hit...
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
