(TEXAS)Help With My AC (Blower Motor Controller) - JeepForum.com
post #1 of 3 Old 06-17-2005, 05:57 PM Thread Starter
Briandl
Well I've talked about this before but things finally got really bad.
I first bought my Jeep about four months or so ago within the first week my AC (99 Grand Cherokee Limited With Automatic Control Zone) momentarily went out when I drove by another Jeep Grand Cherokee, it was like it went from 100% then dipped to 20% then came right back up, this all happened within a second.
A few months later I was driving and hit a slight curve and when I came out of the curve I got no air from the AC, I pulled over about thirty seconds later with the intention of stopping and turning the engine off and restarting to see if it would come back on, well as soon as I stopped it came right back on.
Yesterday things were working perfectly and today when I got into the Jeep no air would blow.
Here is what I know:
Everything lights up.
I get no air from anywhere, in any mode including defrost.
I can hear the compressor click and come on, my RPM's go up slightly.
The part near the firewall on the passenger side in the engine compartment gets cold, as does the plastic part near where the passengers legs are.
If I turn off recirculation some cool air will come through the system.
My conclusion is the blower motor controller so my questions are:
Does anyone agree?
Anyway to check it, clean it, or anything like that?
Is it difficult to replace myself and if so where is it located?
I did find this diagram but I wasn't sure what the location was:
http://www.wjjeeps.com/interior/blower_motor.jpg
Thanks!
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #2 of 3 Old 06-17-2005, 07:06 PM
ddruker
I have had the same problem with my 2000 GC.
The blower controller is a small black box underneath the glove compartment. It comes off easily with a philips screwdriver. . On mine, one of the connectors had overheated and melted. Arcing had caused a buildup of soot / carbon which eventually caused the blower to stop working. I was able to track down the problem just by wiggling the wiring harness going into this box - that would make my blower motor start going again.
Lots of people have this problem - the connectors Jeep uses are probably undersized or too loose causing arcing and overheating.
To fix this I took the wiring harness off, and used fine sandpaper to clean the carbon off of the contacts and I squeezed the female connector with a pliers to make a tighter connection. I then applied conductive grease and voila it's been fixed for a year now.
You could also replace the blower controller and the wiring harness, or you could solder things together to ensure you don't get arcing again.
ddruker is offline
post #3 of 3 Old 06-17-2005, 07:22 PM Thread Starter
Briandl
Thanks for the input.
Once I found where it was I gave it two solid raps with my knuckles and started it up, came on just fine.
I'm thinking I'll take a good look at it and see if anything obvious is wrong, if not I may go ahead and replace it, if something is obvious like the buildup you mentioned I'll try cleaning it first.
I might also try the junkyard before the dealer since the part is 111.00
Briandl is offline
blower motor - blower motor connector melted BradMB2004 ZJ Grand Cherokee Forum 9 10-14-2014 09:57 AM
No pwr to blower motor slowride99 ZJ Grand Cherokee Forum 3 11-08-2009 08:49 AM
Wired up blower motor power module - do I need to replace blower motor? sniperdude ZJ Grand Cherokee Forum 0 04-19-2009 03:33 PM
HELP! Blower Motor, Blower Motor Resistor Fix Already Attempted... No Luck! DJGWJ ZJ Grand Cherokee Forum 3 12-26-2008 01:51 PM
94 JGC, where is the blower motor relay, and where's the blower motor ground wire go? camosilver ZJ Grand Cherokee Forum 1 08-24-2006 11:15 PM
