Teves calipers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Teves calipers
Warn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad15 x 8 Black D-Window Steel Wheels Set of 4
Unread 04-10-2009, 09:03 AM   #1
fisher972002
2002 XJ Cherokee
Teves calipers
Hi Guys
Quick ?.. About to do rear brakes on my 2002 GC. I know about the TSB on the front brakes changing out the calipers from the Black Teves calipers to the newer silver ones..
My rears have the black Teves.. I couldnt find a TSB on the rear brakes, so I assume the black ones are ok to reuse.. Just making sure of course the caliper pins are clean with fresh grease and slide smooth...
When I buy pads for it, I assume all are for the Teves caliper thickness right???
Since mine is a 2002 that's where the confusion comes in since that is when they changed with Jeeps manufactures pre May 2002...
Thanks for your time
fisher972002 is offline   Reply With Quote
Unread 04-10-2009, 09:42 AM   #2
Turbonut
Rears are all the same, no need to replace.
Turbonut is offline   Reply With Quote
Unread 04-10-2009, 11:11 AM   #3
jtsjeep99
The rears should be good to go. The TSB was only on the fronts which led to a class action lawsuit. The fronts get most of the weight when stopping anyway and the rears usually last longer.
jtsjeep99 is offline   Reply With Quote
Unread 04-10-2009, 05:21 PM   #4
05Roadglide
05Roadglide's Avatar
Great, i had that same question, i was confused for a sec cause the PO switched the fronts to ake's.
Fisher, your jeep's a WJ, not a xj, like you have in your profile, welcome fellow 02er
2002 WJ 4.7 242 Laredo Black
05Roadglide is offline   Reply With Quote
