Testing TPS, IAC, MAP - JeepForum.com
post #1 of 1 Old 05-26-2011, 07:50 AM Thread Starter
iflypa28
Hey everyone. I am having a slight problem with my ZJ. It seems to sometimes have a hard time finding idle speed after coming down from a higher rpm, for instance letting of the gas to decelerate or after revving in neutral. When it comes down to idle it goes to a too low of an rpm and takes a second to find idle speed. Sometimes it stalls out completely. I'm pretty sure its not a vacuum leak and I tested fuel system pressure just to cover my bases and its spot on at 49 PSI.
Does anyone know the proper procedure to check TPS, IAC, MAP sensors with a multimeter to see if the are bad or going bad. My service manual is pretty vague.
Also CEL will not illuminate on start up (good bulb i checked) but there are no codes anyway. Just another problem.
Thanks for the help. Any other ideas are welcome!
iflypa28 is offline
CKS testing manavoodoo ZJ Grand Cherokee Forum 1 12-11-2010 02:35 PM
TPS Testing Help Needed mudder1_2000 ZJ Grand Cherokee Forum 1 11-18-2008 12:59 PM
Testing your 4x4 on a 249 T-Case speedbullet2 ZJ Grand Cherokee Forum 32 02-29-2008 01:02 AM
96 ZJ TPS Adjustment/Testing NYCXJ90 ZJ Grand Cherokee Forum 2 07-30-2007 10:05 AM
Testing the PCM turbinesurgeon ZJ Grand Cherokee Forum 2 03-20-2006 12:08 AM
