Quantcast TeraFlex spring spacers? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > TeraFlex spring spacers?
Old 08-18-2007, 05:32 PM   #1
Kruzin
So I got four of these 1.5" TeraFlex coil spacers today for my ZJ (not too thrilled that the store that sold em claims them to be 2"...when used with the existing .5" insulator I later learned ).
Anyway, got the rt ft coil off, only to find this thing will not fit over the bump stop mount. It barely squeezes over the rubber bump stop itself, but when it gets to the metal, there just aint no way
Did they give me the wrong spacers, or is there some trick I'm unaware of?
Kruzin is offline   Reply With Quote
Old 08-18-2007, 06:12 PM   #2
ajmorell
ajmorell's Avatar
You have to take the bumpstop mount off. First remove the bumpstop with a screwdriver or something then there is 1 bolt holding on the mount. Install the spacer then reinstall the mount.
Andy
'98 Jeep ZJ "Pearl"
ajmorell is offline   Reply With Quote
Old 08-18-2007, 06:29 PM   #3
Kruzin
TYVM...Maybe I'll try again tomorrow, if I can find a proper spring compressor. The one I had today wans't the right type, and it seems it would be WAY easier with the right tools
Old 08-18-2007, 06:33 PM   #4
10achik
I ate what?
10achik's Avatar
You need strut compressors for the springs, I know it sounds wierd, but that's the tool.
As far as the spacers, I had to dremel out mine to get them to fit. Not much, just enough to get them to fit, it's kind of tiral and error.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 33" Yokohama Mud Rovers
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Falken 912's (13.76 @ 103.85)
2006 Pontiac G6 GTP - (her's)
2001 Dodge Ram 1500 - CAI, Soft 8's, 31's
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline   Reply With Quote
Old 08-18-2007, 06:59 PM   #5
FortCollinsZJ
Those front bumpstop's are a PITA to remove sometimes... but later when reinstalling just tape the bumpstop to the inside of the spring then after the spring is in take the tape off and use a small prybar to push the bumpstop into place.. some WD-40 or like lubricant helps out.
Nothing here
FortCollinsZJ is offline   Reply With Quote
Glock Forum
