Quantcast Teraflex 4" WJ Springs - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Teraflex 4" WJ Springs
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 09-03-2009, 11:12 AM   #16
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by gatorayde View Post
Man I wish you could've ridden in my WJ down death wobble road at 4.5" on short arms
Short arms do not cause death wobble if that is what you are implying.
98 TJ
Wheelin98TJ is online now   Reply With Quote
Old 09-03-2009, 11:16 AM   #17
gatorayde
DW road = road filled with pot holes = very harsh ride on short arms at 4.5" of lift
gatorayde is offline   Reply With Quote
Old 09-03-2009, 12:00 PM   #18
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Short arms don't cause it, but long arms allow components to last longer and become more resistant to DW. The improved angles are allowing my bushings to last 4 times as long as they did on short arms. Ride is smoother.
So far the LCA's haven't held me up on any rocks, sure I hit them but they just slide over them. I am sure I'll eventually find myself in a situation that they'll hang me up, but until then it is my belly that gets me stuck.
ArloGuthroJeep is offline   Reply With Quote
Old 09-03-2009, 12:23 PM   #19
xJoshxx
xJoshxx's Avatar
2011 WK
~ ~ reason i havent bought any Control arms yet is because i read 4" on Short arms are horrible then i read 4" on short arms no problems
then i read WORST IDEA EVER IS TO LIFT ON SHORT ARMS
then long arms every allways balls deep in these.
Im going to be using tera flex 4" springs RE Monotubes. on short arms Now since i cant afford long arms atm cause IRO doesnt have layaway haha.
which would be better to get first lower adjustables or upper adjustable's or see how it rides on Short Arms?
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 Laredo with ORA1
xJoshxx is offline   Reply With Quote
Old 09-03-2009, 12:55 PM   #20
Wheelin98TJ
JEEP FREAK
Originally Posted by xJoshxx View Post
...which would be better to get first lower adjustables or upper adjustable's or see how it rides on Short Arms?
The first arms to get are adjustable lowers for the front and adjustable uppers for the rear.
The adjustable lowers in the front allow you to adjust caster and dial in your alignment.
Adjustable uppers in the rear allow you to adjust the pinion angle.
Adjustable uppers in the front are mainly used for adjusting the pinion angle and for correcting driveline vibrations. It is rare that you get driveline angle probelms with the front because how much longer the front driveshaft is, so most people opt for the adjustable lowers first so you can align it.
Adjustable lowers in the rear adjust wheelbase. If you lengthen the lowers to get the wheelbase back, you will be tipping the pinion angle on the axle down at the same time. And as you probably already know, tipping the pinion on the axle down is the opposite direction it needs to go when you do a lift. So in other words, if you lengthen the lowers, you also need to lengthen the uppers.
98 TJ
Old 09-03-2009, 12:57 PM   #21
xJoshxx
xJoshxx's Avatar
2011 WK
wj's Do not have adjustable Upper rears you have to add a A-ARM Spacer so only rear lowers are for the WJ
but thanks for the Extra info your profile says WJ Do you have 4 Control arms in the Rear? because the rear on wj's doesnt even have a spot to mount upper control arms
Old 09-03-2009, 01:00 PM   #22
the88thpianoman
Luck favors the prepared
the88thpianoman's Avatar
2003 WJ
No upper control arms in the back of a WJ. Just the lowers and the A-arm.
Edit: beat me to it.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
the88thpianoman is online now   Reply With Quote
Old 09-03-2009, 01:06 PM   #23
ArloGuthroJeep
Mr. Hyde!
He was referring to general suspension geometry...
Old 09-03-2009, 02:25 PM   #24
Wheelin98TJ
JEEP FREAK
Woops, sometimes I forget where I'm posting.
You guys are right - no "uppers" on a WJ but rather an A-arm.
My WJ does still have the stock a-arm setup. I do not have a custom 4-link setup in the WJ.
The info listed in my profile is for my TJ which does have a 4-link rear.
98 TJ
Old 09-03-2009, 02:26 PM   #25
Wheelin98TJ
JEEP FREAK
Even if what I said is not applicable, it does make sense and it applies somehow, right?
98 TJ
Old 09-03-2009, 06:36 PM   #26
darmstro
My teraflex springs came in yesterday. Shipping to Canada after I handed the UPS guy an additional $60 came to about $150. Still a good deal, but fook me. $150 to get $150 springs.
darmstro is offline   Reply With Quote
Old 09-03-2009, 06:49 PM   #27
xJoshxx
xJoshxx's Avatar
2011 WK
why would u hand him more $$$? ive never tipped my UPS guy EVER.
Old 09-03-2009, 07:21 PM   #28
gatorayde
He meant that it cost him an extra $60 in shipping charges to canada.
Old 09-03-2009, 07:35 PM   #29
darmstro
UPS has a tendancy to pick up every nickel and dime in brokerage/customs/duty fees when shipping across the border. USPS, not so much. So yeah, that's $60 extra, or the UPS guy doesn't give you your stuff.
Old 09-03-2009, 08:11 PM   #30
silentbob21
silentbob21's Avatar
so anyone else rockin 4" on short arms... and there is a huge difference between stock arms and short adjustables i am sure... with just trackbar shocks and springs... chances of DW are there, but depending on condition of components, lets say good.... how would it be ? I am more worried about wheel position in the wheel well and driveline angles than anything really. will the stock driveshafts hold up to that ? or would it be better to go with 3" of lift....
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline   Reply With Quote
Glock Forum
