Ten points - JeepForum.com
post #1 of 13 Old 04-12-2013, 08:30 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Ten points
To the first person who can tell me what's wrong with this picture:
Sent from my iPad Nano using JeepForum
kg6mov is offline
post #2 of 13 Old 04-12-2013, 08:35 PM
austin6137
1990 XJ Cherokee
pads are wearing differently front to back?
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #3 of 13 Old 04-12-2013, 08:36 PM
zachjf
pads are beveled, I'll assume one of your slider pins is seized making the caliper pivot on the the stuck one and wearing the pads beveled
Needs parts?
PM
or
zachjf is offline
post #4 of 13 Old 04-12-2013, 09:15 PM
JohnCrabtree
1994 ZJ
Exactly. Pull that slider pin out and grease the crap out of it. When you put it back in see if it is sticking. If it is then you might have a damaged pin.
JohnCrabtree is offline
post #5 of 13 Old 04-12-2013, 09:22 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
It doesn't read from this picture, the pads are on the wrong caliper.
kg6mov is offline
post #6 of 13 Old 04-12-2013, 09:43 PM
austin6137
1990 XJ Cherokee
wtf how are we supposed to know that, they're still beveled we want our dam prize
post #7 of 13 Old 04-12-2013, 10:05 PM
riot1987
Build thread^^
riot1987 is offline
post #8 of 13 Old 04-12-2013, 11:15 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
They are beveled, ten points. I thought I took a better picture, as I was being dragged out the door by the GF.
kg6mov is offline
post #9 of 13 Old 04-13-2013, 01:15 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
if you look at it hard enough you'll realize they're upside down, and the wear is beveled because of that and the slide pins sticking.
ratmonkey is offline
post #10 of 13 Old 04-13-2013, 07:08 AM
austin6137
1990 XJ Cherokee
So do we all split the 10 points or do we each get 10 points, and how do we redeem them. Lol
post #11 of 13 Old 04-13-2013, 08:57 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Caliper pin boot has a hole in it.
HighLonesome is offline
post #12 of 13 Old 04-13-2013, 11:07 PM
durango-bob
2006 WK
You have one left hand pad and one right hand pad on there.
durango-bob is offline
post #13 of 13 Old 04-14-2013, 04:56 AM
jmonty0523
While your in there, also check the knuckles for wear from where the pads stick. Mine had little grooves from the pads.
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
