Temperature Gauge swinging - JeepForum.com
post #1 of 8 Old 02-17-2002, 11:23 PM Thread Starter
Humberto Benavides
Humberto Benavides's Avatar
Hi There, this is my first post, I bought days ago a 1995 Jeep Grand Cherokee and while driving from Houston to my Home in Laredo (Texas), the Temperature gauge started swinging from 210 to the next lower point, then stayed there for about 5 seconds and then went again to the 210 mark, stayed at 210 for 5 seconds and then again swing to the next lower mark......? What can be wrong....? Water Temp Sensor....? Faulty Radiator Cap.....? The Jeep runs smoothly with no problems at all and the water temp is good.
'03 Jeep Wrangler X Auto I6 4.0L, 3.5" RE Super Flex, 1" PA BL, M.O.R.E. 1" MML, 33x12.5x15 MT/R's, JKS Quick Discos, RE Front Adjustable Trackbar, Skyjacker Hydro7000 Shocks, OEM RUBICON Rocker Guards, WARN Steering Skidplate, Front Mopar Tow Hooks, Bushwacker 6" Extended Fender Flares, K&N drop-in air filter, Chicago Electric Winch, SS light bar with 4 Hella 500 Driving Lights, and stock no more !
OOOO
[ŻŻŻŻ]
o||||o
▒-o-▒
Humberto Benavides is offline
post #2 of 8 Old 02-18-2002, 05:36 AM
JeffsJGC
Probably a bad sensor or sending unit. They run about 10-12 bucks. I'd give it a shot.
'93 GC Laredo 4.0 I-6 (120,000+!!)
JeffsJGC is offline
post #3 of 8 Old 02-19-2002, 09:21 AM Thread Starter
Humberto Benavides
Just changed the coolant temperature sensor and the gauge keeps swinging from one mark to another, may be the thermostat......? Any advice......?
Thanks to all !
OOOO
[ŻŻŻŻ]
o||||o
▒-o-▒
post #4 of 8 Old 02-19-2002, 11:15 AM
Big Dumb White Guy
Big Dumb White Guy's Avatar
i would guess thermostat. try it. if not move on to next idea. no harm done with a new one....
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
post #5 of 8 Old 02-19-2002, 11:29 AM Thread Starter
Humberto Benavides
Is it easy to replace the thermostat in this engine....? 6 cyl 4.0 in line....! What do I need to remove to get the thermostat out and replace it with a new one.......? Do I need a kind of sealer or just put the thermostat and that is . . . ?
OOOO
[ŻŻŻŻ]
o||||o
▒-o-▒
post #6 of 8 Old 02-19-2002, 03:11 PM
Big Dumb White Guy
never done one. can't be too hard though...
get yourself a Haynes or Chiltons book. $15 well spent. checkc at an Autozone. those'll tell you an awful lot.
can anyone help on the thermostat swap?
repost Nazi's suck!
post #7 of 8 Old 02-19-2002, 03:19 PM Thread Starter
Humberto Benavides
I just get the thermostat off my Jeep hours ago, so I went to an autozone to get the thermostat, the thermostat seal, and the gasket for the housing, get off is easy, so I guess is easy to put the new thing on !!! I'll make the gasket my self, hope this work will be easy !!! I'll post results tomorrow, ok.....?
OOOO
[ŻŻŻŻ]
o||||o
▒-o-▒
post #8 of 8 Old 02-20-2002, 11:51 AM Thread Starter
Humberto Benavides
The temperature gauge swinging problem just went away !!! The thermostat was replaced with sucessfully results ! Now the temperature gauge is more stable and the temperature lower (180 grade Thermostat installed) ! The only problem about changing the thermostar is the lower 1/2" bolt in the housing is obstructed by the band, really hard to get this bolt off, but finally the work is done !
Thanks all for your advice !
OOOO
[ŻŻŻŻ]
o||||o
▒-o-▒
Temperature gauge - '93 ZJ MAUSS ZJ Grand Cherokee Forum 8 02-12-2012 01:33 PM
Temperature Gauge Fluctuates dbone ZJ Grand Cherokee Forum 1 05-22-2009 11:04 AM
95' ZJ Temperature Gauge??? bcridez3 ZJ Grand Cherokee Forum 4 03-26-2008 08:19 AM
temperature gauge srqcherokkee ZJ Grand Cherokee Forum 3 09-23-2007 04:46 PM
temperature gauge wilreyca ZJ Grand Cherokee Forum 4 03-30-2005 11:24 AM
