Temp Switch Sender/Coolant Temp Sensor - JeepForum.com
post #1 of 4 Old 07-09-2011, 08:32 PM Thread Starter
pennyduke
Can anyone show me where these 2 sensors or senders are on a 1996 ZJ 4.0L. I read that one of them has 2 wires and the other is has 1 wire. I have one on the T-Stat housing and one on the intake manifold. They look the same but have different part numbers. Im replacing everything to do with the cooling system one part at a time until it quits overheating.Thanks
pennyduke is offline
post #2 of 4 Old 07-09-2011, 08:35 PM
TheHalfWit
Since yours is a 96 you should only have 1 sender. The 96-98 had the gauge ran by the pcm with no need for a second sender.
The one on the thermostat should be the only coolant temperature sender you have. The 93-95 4.0's had a second sender on the very back of the block, under the wiring for the injectors, 3" from the firewall and a ***** to change.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #3 of 4 Old 07-09-2011, 09:03 PM Thread Starter
pennyduke
reply
The parts store gave me 2 numbers for the 1996. Coolant Temp Sensor (WT3027Z) and a Temp Switch/Sender (WT428P). They both look just like the one on the Intake. Im pretty sure no coolant flows through the Intake.
post #4 of 4 Old 07-09-2011, 10:08 PM
TheHalfWit
That sounds like the IAT, what you want is the sensor that plugs into the side of the thermostat housing/water outlet.
Calm. C.
coolant temp sensor ilive4cars0122 ZJ Grand Cherokee Forum 7 11-15-2010 08:03 PM
Coolant Temp Sensor gham ZJ Grand Cherokee Forum 6 07-08-2010 12:27 PM
coolant temp sensor problems kroymander ZJ Grand Cherokee Forum 4 09-14-2007 07:18 AM
Coolant Temp Sensor 4wdLaredo94 ZJ Grand Cherokee Forum 11 10-04-2006 02:45 PM
Coolant temp sensor? Wiley ZJ Grand Cherokee Forum 6 05-27-2006 02:44 AM
