temp fix for blend doors? - JeepForum.com
post #1 of 8 Old 12-01-2009, 07:59 AM Thread Starter
painted600rr
my blend doors are f'ed and i dont have the money right now to buy a heatertreater. i drive about an hour in my jeep to and from work. was wondering if i could just cut behind the glove box and temporary flip the blend doors so that they just blow hot air all the time. im also assuming that i would have to remove the blend door motor as well if i can do this.
painted600rr is offline
post #2 of 8 Old 12-01-2009, 08:55 AM Thread Starter
painted600rr
i went ahead and did it anyways. i have heat! muahahha im so happpy!
post #3 of 8 Old 12-01-2009, 09:37 AM
CanadianZed-J
I did this to mine too, but only on the passenger side. Had I seen this thread sooner I would have posted a link to another where I posted a small write-up.
I drilled a hole inbetween the two doors, lifted the pass. door up then put a wood screw in it.
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline
post #4 of 8 Old 12-01-2009, 10:55 AM Thread Starter
painted600rr
CZJ.
thats gives me a good idea. thanks!
post #5 of 8 Old 12-01-2009, 01:45 PM
jclaudii
That is what I did to mine, but come to find out my hard to reach servo was stuck. After I cut the hole in the plastic I find this out, but at least I'm prepaired for a failure now
jclaudii is offline
post #6 of 8 Old 12-02-2009, 12:10 AM
Blktjsport
Don't mean to hijack but it's relavant kinda anyways I would if this is my problem I have a 2001 wj Laredo with manual air and my passenger side doesn't get any air if it is the blend door are there any write ups on cutting the hole thanks in advance
2001 WJ -WIFES K&N FIPK~2.5" FLOWMASTER 40~2.5" BB~ BILSTEINS~ 255/70/18 BRIDGSTONE A/T JK'S
1999 TJ SPORT- NP242~SYE~K&N APOLLO COWL CAI~2.5" FM40 ~3.5" RE~ BILSTEIN 5100~D44~33" BFG MT~ DAVES RACK~ BUSHWACKERS~ HELLA ECODE DDM 6K HID
Blktjsport is offline
post #7 of 8 Old 12-02-2009, 12:32 PM
jclaudii
If it's not blowing, then your resistor or a fuse may be blown. This fix is for when it only blows cold or hot. If you have manual control, you can probably pull the servo off behind the glovebox and try turning the flapper with your hand.
jclaudii is offline
post #8 of 8 Old 12-07-2009, 03:51 PM
RaccoonJoe
to OP:
What was your original problem? You had no heat at all, or just had no control over where the heat went? Also, what year is your beast?
Trying to diagnose/repair 95 ZJ. Selector is stuck on floor, and my heat is only lukewarm........No money for the heatertreater, and I've got to get this fixed before it gets too much colder.
Eagle Scout Jeep Club Member #4
Originally Posted by 4.0H.O.XJ
Ill have an XJ please, with a side order of 4.0, hold the catalyctic converter and the 02 sensors, thank you.
RaccoonJoe is offline
Temp blend door fix - could this work? dukabor ZJ Grand Cherokee Forum 16 01-07-2011 12:46 AM
Temp Control Issue .... its NOT the blend doors. Jeepn-n-tx ZJ Grand Cherokee Forum 0 11-17-2009 09:25 PM
blend door actuator or manual temp. control ? sp3 ZJ Grand Cherokee Forum 2 02-13-2009 09:14 AM
how can i get to the blend doors? wjtom ZJ Grand Cherokee Forum 2 10-11-2007 05:29 AM
WJ Dual Zone Temp Blend Door Actuators - Where are they? JoeyJoJo ZJ Grand Cherokee Forum 3 10-06-2004 11:43 PM
