Technical Service Bulletins ? - JeepForum.com
post #1 of 9 Old 08-01-2007, 09:35 PM Thread Starter
kdt1970
how do you go about getting a TSB taken care of? is it somthing the dealer has to fix or is it more like a suggestion for them to repair.
2003 Jeep Rubicon
kdt1970 is offline
post #2 of 9 Old 08-01-2007, 09:38 PM
WBowie
Do you have a particular TSB in mind? Just show up to the dealership with a copy of the TSB in hand.
WBowie is offline
post #3 of 9 Old 08-01-2007, 09:40 PM Thread Starter
kdt1970
I just bought a 2003 Rubicon and looked them up along with the Grand Cherokee
there seems to alot for both.
2003 Jeep Rubicon
kdt1970 is offline
post #4 of 9 Old 08-01-2007, 09:43 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
There is a lot for any vechile. Nothing you need to repair unless the discibed problem becomes an issue.
2013 FR-S
BlaineWasHere is offline
post #5 of 9 Old 08-01-2007, 09:46 PM Thread Starter
kdt1970
Right, but once it becomes a problem is it the dealers problem to fix with there time and $ or is it the vehicle owners problem to spit out the $?
2003 Jeep Rubicon
kdt1970 is offline
post #6 of 9 Old 08-01-2007, 10:55 PM
BlaineWasHere
BecauseRacecar
Lucky for you, you have to pay. Just beucase it is a TSB does not mean you WILL have that problem... just a higher probability of it.
2013 FR-S
post #7 of 9 Old 08-02-2007, 05:15 AM
georged
A TSB is a repair procedure given by the manufacturer to the dealer repair shops to help them diagnose and repair common/difficult problems. There is NO obligation for the manufacturer or dealer to do the repairs free. They are an addition to the factory shop manual repair and diagnosis procedures.
If a TSB covers a problem you are having while your vehicle is under warranty it would be free.
georged is offline
post #8 of 9 Old 08-02-2007, 06:39 AM
merlinTec
merlinTec's Avatar
A recall however would be free
merlinTec is offline
post #9 of 9 Old 08-02-2007, 07:35 AM
ta2oodfreak
ta2oodfreak's Avatar
just like georged said, a tsb is not a recall. tsb's are issued by any company to aid techs in diagnosis of fairly common problems. a common problem does not mean a recall is necessary. tsb's are more of a suggestion of somthing to check and if the symptoms are right a possable fix. tsb's can be restricted to certain vin ranges, build dates and many of the options codes.
96 ZJ
TREC Series #44
ta2oodfreak is offline
Technical Service Bulletin Questions... J_Minnesota ZJ Grand Cherokee Forum 5 01-24-2009 02:50 PM
Technical Service Bulletin on WK Auto Windows BigSensFan WK Grand Cherokee & XK Commander Forum 4 04-22-2008 09:46 PM
Technical Service Bulletins Meerkat ZJ Grand Cherokee Forum 68 09-04-2005 09:25 PM
Full text Technical Bulletins - Anyone? 2Xtreme ZJ Grand Cherokee Forum 4 12-17-2003 09:10 PM
Question on tech service bulletins?? BostonBull ZJ Grand Cherokee Forum 4 06-05-2003 08:39 PM
