Jeep Enthusiast Forums banner
Technical Service Bulletins
76K views 68 replies 2 participants last post by  Meerkat
#1 ·
Thought I would start a thread to link to the FAQ listing all the TSB's I can find. I'll add to them here as I can in no particular order....
A/T - ATF Usage List
NUMBER: 21-004-04
GROUP: Transmission
DATE: March 16, 2004
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-006-01, DATED JUNE 29, 2001, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN ADDED TO HIGHLIGHT REVISIONS.
SUBJECT:
Automatic Transmission Fluid Usage ATF+4 (Type 9602)
MODELS:
NOTE : This bulletin applies to all transmissions manufactured by Chrysler except for 1999 and earlier minivans with the 41TE/AE transmission. This Service Bulletin DOES NOT apply to all AWD transmissions, Sprinter transmissions, Crossfire transmissions and WG bodies equipped with a W5J400 or NAGI transmission (sales code DGJ).
DISCUSSION:
A new transmission fluid (ATF+4(R) - Type 9602) has been developed and is being used as factory fill for all vehicles with Chrysler automatic transmissions. It is recommended that all vehicles with Chrysler automatic transmissions EXCEPT FOR THOSE LISTED ABOVE be serviced with ATF+4(R).
NOTE :ATF+4(R) must always be used in vehicles that were originally filled with ATF+4(R).
NOTE :Service intervals do not change. The service interval currently in effect for a given vehicle should continue to be followed.
NOTE :ATF+4(R) is compatible with ATF+3 and ATF+2. ATF+4(R) can be used to top off vehicles that currently have ATF+2 or ATF+3. Do not use ATF+2 or ATF+3 to top off vehicles that have ATF+4(R) fluid.
BENEFITS
Better anti-wear properties
Improved rust/corrosion prevention
Controls oxidation
Eliminates deposits
Controls friction
Retains anti-foaming properties
Superior properties for low temperature operation
FLUID COLOR
Mopar ATF+4(R) is a World Class Fluid having exceptional durability. However, the red dye used in ATF+4(R) is not permanent; as the fluid ages it may become darker or appear brown in color. ATF+4(R) also has a unique odor that may change with age. With ATF+4(R) fluid, color and odor are no longer indicators of fluid condition and do not support a fluid change.
POLICY:
Information Only
Disclaimer :This bulletin is supplied as technical information only and is not an authorization for repair.
See less See more
#27 ·
Recall 00V136000: Front Disc Brake Rotor Corrosion
Passenger and multi-purpose vehicles originally sold in (or are currently registered in) the States of Connecticut, Illinois, Indiana, Maine, Maryland, Massachusetts, Michigan, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, or Wisconsin, and the District of Columbia. The front disc brake rotors can experience severe corrosion if operated for an extensive period in the "salt belt." If the rotors are not replaced, the corrosion can eventually compromise the structural integrity of the stamped steel center hub section of the rotor.
The reduced strength can allow the cast iron wear surface to separate from the hub, reducing the brake effectiveness of the vehicle.
Dealers will replace these rotors with rotors that are coated with a corrosion protection.
Owner notification began June 5, 2000. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact DaimlerChrysler at 1-800-992-1997. Also contact the National Highway Traffic Safety Administration's Auto Safety Hotline at 1-888-DASH-2-DOT (1-888-327-4236).
#29 ·
Front Hub Seals - Grease Purge Explanation
NUMBER: 02-06-99 Rev. A
GROUP: Suspension
DATE: Dec. 17, 1999
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 02-06-99, DATED JUNE 11, 1999, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE THE ADDITION OF 4X2 MODELS AND ADDITIONAL MODEL YEARS.
SUBJECT:
Front Wheel Bearing Grease Is Evident On The Bearing Seal Area.
MODELS:
1997 - **2000** (AN) Dakota
1994 - **2000** (BR/BE) Ram Truck
1998 - **2000** (DN) Durango
DISCUSSION:
Front wheel bearings may be incorrectly diagnosed as faulty due to the evidence of wheel bearing grease on the bearing seal areas. This grease purge is a normal design condition. The factory fill of the bearings includes a slightly greater amount of grease than is required for the bearing lifetime lubricant. A portion of the grease purges through the self-venting seal in the initial few thousand miles to form an additional barrier in the area of the seal and the stamped slinger. This barrier aids in the prevention of contaminants passing through the seal and into the bearing. Do not remove or clean the purged grease as part of normal maintenance due to the fact that it provides additional protection and once removed, damage to the seal and bearing could result.
NOTE :UNDER NORMAL CONDITIONS, THERE MAY BE A SPLATTERING OF GREASE RADIALLY OUTWARD ON THE STEERING KNUCKLE FROM THE GREASE BARRIER AREA THAT CAN BE AS THICK AS 4 MM (0.125 IN.).
Front wheel bearings should be replaced only if:
The seal shows visible damage
The bearing endplay is greater than 0.13 mm (0.005 in.)
The bearing was operated without the proper clamping force from the spindle nut
The bearing has a rough, sticky feel when rotated
POLICY: Information Only
#30 ·
Heated Seat - Inoperative
NUMBER: 08-03-99
GROUP: Electrical
DATE: Feb, 5, 1999
SUBJECT:
Inoperative heated seat.
OVERVIEW:
This bulletin involves installing heated seat heating element repair kits.
MODELS:
1996 - 1998 (ZJ) Grand Cherokee
SYMPTOM/CONDITION:
The heated seat may be inoperative due to an open circuit in the heating element located in the seat cover. The condition is usually present in the seat bottom. This Technical Service Bulletin provides a Repair Procedure, which eliminates the need to replace the seat bottom cover.
DIAGNOSIS:
Disconnect the 4 way connector under the seat bottom at the rear of the seat. Check continuity between pins A and B with a digital ohm meter on the seat side of the harness (See Figure 1). The Resistance should be between .9 and 1.4 ohms. If the circuit is open, Perform the Repair Procedure. If continuity is present and the resistance value are correct and the heated seat is inoperative, further diagnosis is present. Refer to the appropriate service manual for diagnostics.
PARTS REQUIRED:
2 05015478AA Heated Seat Repair Kit (2 required per seat)
POLICY: Reimbursable within the provisions of the warranty.
TIME ALLOWANCE:
Labor Operation No: 23-20-38-90/91 1.4 hrs.
FAILURE CODE: AM - Authorized Modification
#31 ·
Heated Seat - Inoperative Repair Procedure
1. Position the seatback in the half recline position to gain access to the fasteners.
2. Disconnect the wire harness from the seat assembly.
3. Remove the seat attaching nuts and remove the seat from the vehicle.
4. Remove the seat cushion side cover trim.
5. Remove the recliner to seat cushion bolts and inboard seat back to seat cushion bolt. Remove the seat back.
CAUTION :CARE MUST BE USED WHEN REMOVING THE COVER FROM THE SEAT BOTTOM. THE SEAT IS ATTACHED TO THE FOAM CUSHION WITH HOOK AND LOP FASTENERS. THESE CAN BE TORN WHEN THE COVER IS REMOVED. USE CARE TO CAREFULLY REMOVE THE COVER TO AVOID TEARING THE HOOK AND LOOP FASTENER FROM THE FOAM. IF THE FASTENER IS TORN IT MUST BE ATTACHED TO THE FOAM USING A SUITABLE ADHESIVE SUCH AS MOPAR SPRAY ADHESIVE, P/N 04856957 OR EQUIVALENT.
6. Disengage the seat cover J straps from the frame. Carefully remove the cover from the seat bottom making sure not to damage the hook and loop fastener on the foam cushion.
7. The system contains two heating elements per seat. Unplug the two wire connectors and check the continuity between the two terminals in each connector to determine which heating element is open (See Figure 1). The resistance should be .9 to 1.4 ohms. An infinite resistance indicates an open circuit. Each repair kit will repair one element. It is recommended that both elements be repaired even if only one is open.
8. Trace the wires into the foam and carefully slit the foam using a sharp knife, following the wires until the heating element solder joint is located (See Figure 2). This is the location the open circuit is usually found. Cut the harness from the element as close to the solder joint as possible. If the seat cover has a gray lining, it may be necessary to trim some of the fabric around the glue until the element is exposed. Remove all loose debris. It is not necessary to remove the glue from the cover. Do not discard the original harness. Some vehicles will require the use of the original two wire connector later.
9. There were two types of heating element used in production (See Figure 3). One has insulation on the wire and one does not. If the element has insulation on the wire, carefully strip one inch of the insulation from the element to allow for soldering. Pull the elements away from the cover enough to clear the foam for soldering. Trim the foam as necessary to provide adequate clearance for soldering.
10. The soldering procedure requires a technician skilled in soldering fine electrical/electronic wiring. Using a soldering iron and rosin core, solder the new harness to the heating element as shown in Figure 4. Do not use any soldering equipment utilizing an open flame for this procedure. This could damage the foam cushion. Make sure utilize the proper soldering procedures and heat the wire hot enough to melt the solder to avoid a cold solder joint. Cut piece of heat shrink tubing in half and install it on the wire as shown. Shrink the tubing using a heat gun.
11. Peel of the paper backing from the adhesive patch on the new harness and secure the harness to the cover as shown. The elements require at least one inch clearance between each other to eliminate the possibility of them shorting together. Make sure to route the wires as shown and install the cover patch to fully secure the new harness to the cover. Trim the cover patch as necessary to clear the hook and loop fasteners.
12. The new harness will plug into most of the existing seat harnesses. Some vehicles utilized a red insulator, which is keyed differently than the green insulator provided on the new harness. If the vehicle utilizes the red connector, it will have to be removed from the original harness and installed on the new harness using solder and heat shrink tubing as shown in Figure 5. Be sure to stagger the splices as shown.
13. Check continuity at both of the two wire connectors to assure good solder joint.
14. Repeat this process for the second heating element.
15. Install the seat cover to the seat bottom.
16. Install the seat back.
17. Install the seat and connect the harness.
#33 ·
Engine - Spark Knock/Oil Consumption
NUMBER:
09-05-00
GROUP:
Engine
DATE:
Feb.25, 2000
MODELS:
1994 - 1999 (AB) Ram Van
1994 - 1999 (AN) Dakota
1994 - 1999 (BRIBE) Ram Truck
1998 - 1999 (DN) Durango
1994 - 1998 (ZJ) Grand Cherokee
1996 - 1998 (ZG) Grand Cherokee
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 09-06-99, DATED SEP.10, 1999, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT REVISIONS.
SUBJECT:
Spark Knock And Engine Oil Consumption Due To Intake Manifold Pan Gasket Oil Leak
OVER VIEW:
This bulletin involves the replacement of the engine intake manifold plenum pan gasket.
NOTE: THIS BULLETIN APPLIES TO VEHICLE EQUIPPED WITH A 3.9L, 5.2L. OR 5.9L GASOLINE ENGINE.
SYMPTOM/CONDITION:
An engine intake manifold plenum pan gasket oil leak may occur on some V-6 and V-8 style engines. The oil leak is internal to the engine so no external oil leakage will be present. Two symptoms of this oil leak condition may be present. The vehicle operator may experience an engine spark knock during acceleration and/or an increase in the amount of engine oil consumed by the engine.
DIAGNOSIS:
Make sure Technical Service Bulletin (TSB) 18-48-98 has been performed.
NOTE: IT IS IMPORTANT THAT THE COIL AND SPARK PLUG WIRES ARE ROUTED EXACTLY AS SPECIFIED IN TSB 18-48-98 TO ACHIEVE THE MOST BENEFIT.
Inspect the Positive Crankcase Ventilation (PCV) valve. Shake the PCV valve to verify that the pintle inside of the PCV valve is free. Replace the PVC if the pintle is not free.
If the intake manifold plenum pan gasket is leaking, an additional vacuum source will be created inside of the engine at the location of the pan gasket leakage. Engine combustion blow-by gases, oil vapor, and air from the crankcase filter/breather may be drawn past the leaking pan gasket and into the intake manifold. In most cases when this condition occurs, an engine at idle will create the highest vacuum and lowest amount of engine blow-by.
1. Allow the engine to reach normal operating temperature.
2. Stop the engine.
3. Disconnect the breather hose from the air cleaner.
4. Attach a vacuum/pressure gauge to the end of the breather hose (Figure 1).
5. Disconnect the PCV valve hose from the intake manifold.
6. Seal off the intake manifold PCV valve hose port opening.
7. Seal off the open end of the PCV valve hose (Figure 2).
NOTE: DURING THIS DIAGNOSIS, IT WOULD BE NORMAL FOR THE ENGINE TO DEVELOP PRESSURE WITHIN THE ENGINE CRANKCASE. THIS IS DUE TO THE NORMAL PROCESS OF EXHAUST BLOW-BY GASES LEAKING PAST THE ENGINE PISTON RINGS AND ACCUMULATING IN THE ENGINE CRANKCASE. DO NOT ALLOW MORE THAN 3 PSI (20.7 kpa) OF PRESSURE TO BUILD WITHIN THE ENGINE WHEN PERFORMING THE FOLLOWING DIAGNOSTIC PROCEDURE.
8. Start the warmed engine and observe the vacuum gauge.
9. Allow the engine to idle for approximately 30 seconds. Do not allow more than 3 psi (20.7 kPa) of pressure to develop in the engine crankcase.
10. If the attached vacuum / pressure gauge does not indicate that a vacuum is present in the engine crankcase, then the intake manifold plenum pan gasket is good and no further internal engine vacuum leak diagnosis is required.
11. If an internal vacuum leak is present then perform the Repair Procedure.
PARTS REQUIRED:
For the 5.2L / 5.9L:
1 04897383AC Package, Intake Manifold Flange Gasket and Bolts
1 05017208AA Gasket, Intake Manifold Plenum Pan
15 06034583 Bolt, Intake Manifold Plenum Pan
1 53030541 Gasket, Throttle Body
2(AR) 04318001 Conditioner, Combustion Chamber
For the 3.9L:
1 04897382AC Package, Intake Manifold Flange Gasket and Bolts
1 05017207AA Gasket, Intake Manifold Plenum Pan
14 06034583 Bolt, Intake Manifold Plenum Pan
2(AR)04318001 Conditioner, Combustion Chamber
REPAIR PROCEDURE:
1. Refer to the appropriate year Service Manual, Section 9: ENGINE for removal and installation instructions.
NOTE: CLEAN ALL OIL RESIDUE FROM THE INTERIOR SURFACES OF THE PLENUM PAN AND THE INTAKE MANIFOLD PLENUM CHAMBER.
NOTE: THE PROPER BOLT TORQUE AND TIGHTENING SEQUENCE IS CRITICAL AND MUST BE FOLLOWED WHEN TIGHTENING BOTH THE PLENUM PAN BOLTS AND THE INTAKE MANIFOLD FLANGE BOLTS.
3.9L Bolt Tightening Sequence and Torque Procedure:
3.9 Plenum Pan Bolt Torque Procedure
3.9 Intake Manifold Flange Bolt Torque Procedure
5.2L / 5.9L Plenum Bolt Tightening Sequence and Torque Procedure:
5.2L / 5.9L Plenum Pan Bolt Torque Procedure
5.2L / 5.9L Intake Manifold Flange Bolt Torque Procedure
2. With the engine reassembled, inspect the coil and spark plug wires for proper routing. Refer to TSB 09-48-98 for additional assistance.
3. Start the engine and allow it to warm to normal engine operating temperature.
4. Decarbon the combustion chamber using Mopar Combustion Chamber Conditioner (p/n 04318001) per the instructions.
NOTE: ALLOW THE COMBUSTION CHAMBER CLEANER TO SOAK INSIDE OF THE ENGINE FOR 2 TO 2.5 HOURS.
NOTE: A SECOND APPLICATION OF THE COMBUSTION CHAMBER CONDITIONER MAY BE REQUIRED IF THERE WAS A LARGE QUANTITY OF OIL LEAKAGE PAST THE INTAKE PLENUM PAN GASKET.
5. Verify proper engine oil level.
Time Allowance
FAILURE CODE: P8- New Part
#37 ·
TCM - MIL ON/DTC P1763 Set
NUMBER: 21-04-00
GROUP: Transmission
DATE: June 3O, 2000
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 18-07-99, DATED APRIL 30, 1999, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE REVISED MODEL YEARS.
SUBJECT:
Erroneous MIL Illumination For P1763 - Trans. Governor Pressure Sensor Volts Too High
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the JTEC Powertrain Control Module (PCM) with new software (calibration change 96Cal18, 97Cal18, 98Cal12, and 99Cal14).
MODELS:
**1996** - 1999 (AB) Ram Van
**1996** - 1999 (AN) Dakota
**1996** - 1999 (BR/BE) Ram Truck
**1997** - 1999 (TJ) Wrangler
**1996** 1999 (XJ) Cherokee
**1996** - 1998 (ZJ) Grand Cherokee
NOTE :THIS INFORMATION APPLIES TO VEHICLES EQUIPPED WITH AN RE SERIES AUTOMATIC TRANSMISSION BUILT BEFORE DECEMBER 18, 1998 (MDH 1218XX).
SYMPTOM/CONDITION:
Some vehicles may exhibit a MIL illumination with a Diagnostic Trouble Code (DTC) of P1763 - Transmission Governor Pressure Sensor Volts Too High. The vehicle operator may experience slower than normal vehicle accelerations because the transmission may have temporarily entered its third gear "Limp-In" mode as a result of the DTC. The "Limp-In" mode may last until the vehicle owner cycles the ignition key. The technician may not detect a problem with the automatic transmission during a diagnostic test or test drive.
The MIL is caused by an increase in hydraulic pressure. The increased hydraulic pressure is the result of a new valve body machining process, which entered into production January 1, 1998. This condition will occur most often with vehicles that were built between January 1, 1998 and December 18, 1998.
Vehicles built prior to January 1,1998 may also experience this condition if the valve body or the transmission assembly is replaced with components built after January 1, 1998.
DIAGNOSIS:
Using the Mopar Diagnostic System (MDS2) and or the Diagnostic Scan Tool (DRB III(R)), with the appropriate Diagnostic Procedures Manual, verify that all engine and transmission systems are functioning as designed. If Diagnostic Trouble Codes (DTC's) are present, record them on the repair order and repair as necessary before proceeding further with this bulletin. If no DTC's are present, and the above symptom has been experienced, perform the Repair Procedure.
NOTE :WHENEVER A POWERTRAIN (PCM) IS REPLACED DUE TO FAILURE, THE SOFTWARE OF THE REPLACEMENT CONTROLLER MUST BE VERIFIED FOR THE LATEST REVISION LEVEL. USE THE FLASH PROCEDURE TO UPDATE REPLACED CONTROLLERS AS NECESSARY.
PARTS REQUIRED:
1 04669020 Label, Authorized Software Update
1 04275086 Label, Authorized Modification
EQUIPMENT REQUIRED:
1 CH6000 Scan Tool (DRB III(R))
1 CH7035 General Purpose Interface Bus Cable (GPIB)
1 CH7000/7001 J1962 Cable
1 MDS2
NOTE :THE MDS2 AND DRB III(R) ARE REQUIRED TO PERFORM PART OF THIS REPAIR. WHEN USING THE MDS2 AND THE DRB III(R), THE SYSTEM MUST BE OPERATING AT CIS CD 2061 OR HIGHER.
REPAIR PROCEDURE:
1. Log onto the MDS2 system.
2. Connect the MDS2 and DRB III(R) to the vehicle and switch the ignition key to "ON".
3. Use the arrow keys and select # 2 CONNECT TO MDS2 on the DRB III(R) MAIN MENU SCREEN.
4. Use the arrow keys and select # 2 RUN MDS2 APPLICATION on the DRB III(R) MAIN MENU SCREEN.
NOTE :ONCE MDS2, DRB III(R), AND VEHICLE COMMUNICATION HAS BEEN ESTABLISHED, THE "CANNOT READ VIN FROM DRB III(R)" MESSAGE (ON THE MDS2) WILL BE REPLACED BY THE VEHICLE VIN. PRESS THE "OK" BUTTON ON THE MDS2 TO REQUEST A MDS2 SESSION FOR THE VEHICLE VIN INDICATED. PRESS THE "OK" BUTTON WHEN ASKED TO BEGIN SESSION.
5. Select the FLASH tab on the MDS2.
6. Select READ PART NUMBERS FROM VEHICLE and click SHOW UPDATES on the MDS2. Press the "OK" button.
NOTE :IN ABOVE STEPS # 5 AND/OR # 6, A MESSAGE MAY APPEAR THAT INDICATES NO UPDATES ARE AVAILABLE. IF THIS OCCURS, MAKE SURE YOUR DIAGNOSTIC EQUIPMENT IS OPERATING AT THE LATEST SOFTWARE LEVEL AS LISTED EARLIER IN THIS BULLETIN. IF THE LATEST SOFTWARE IS INSTALLED, AND NO UPDATES ARE AVAILABLE, ANOTHER VEHICLE CONDITION EXISTS THAT WILL REQUIRE FURTHER INVESTIGATION.
7. Select the new software part number with the light pen and click UPDATE CONTROLLER SOFTWARE.
8. The MDS2 and DRB III(R) will prompt for any operator action needed during the remainder of the reprogramming process.
NOTE :DUE TO THE PCM REPROGRAMMING PROCEDURE, A DTC MAY BE SET IN OTHER MODULES (EATX, BCM, MIC, SKIM) WITHIN THE VEHICLE, IF SO EQUIPPED. SOME DTC'S MAY CAUSE THE MIL TO ILLUMINATE. ALL DTC'S RELATE TO A LOSS OF COMMUNICATIONS WITH THE MODULE THAT IS BEING REPROGRAMMED. CHECK ALL MODULES, RECORD THE FAULTS, AND ERASE THESE FAULTS PRIOR TO RETURNING THE VEHICLE TO THE CUSTOMER. ERASE ANY FAULTS IN THE PCM ONLY AFTER ALL OTHER MODULES HAVE HAD THEIR FAULTS ERASED.
NOTE :THE FOLLOWING STEPS ARE REQUIRED BY LAW.
9. Type the necessary information on the "Authorized Software Update Label" p/n 04669020 (Figure 1). Attach the label to the JTEC PCM and cover the label with the clear plastic overlay.
10. Type the necessary information on the "Authorized Modification Label" p/n 04275086 and attach the label near the VECI label (Figure 2).
TIME ALLOWANCE:
Labor Operation No: 08-19-42-99 0.5 Hrs.
FAILURE CODE: FM - Flash Module
#38 ·
Air Bag System - ON-OFF Switch Availibility
NO: 08-17-98 Rev. C
GROUP: Electrical
DATE: Dec. 30, 1998
SUBJECT:
Airbag On-Off
Switches
THIS REPAIR IS COMPATIBLE WITH DAIMLERCHRYSLER'S MOBILE SERVICE PROGRAM AND DOES NOT REQUIRE HOISTS OR OTHER FULL SERVICE FACILITY SPECIAL EQUIPMENT.
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 08-17-98 Rev. B DATED SEPTEMBER 18, 1998 WHICH SHOULD BE REMOVED FROM YOUR FILES. ADDITIONAL MODELS HAVE BEEN ADDED. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS**.
MODELS:
**1990 - 1995 (AA) Spirit/Acclaim/Lebaron Sedan**
1995 - **1999** (AB) Ram Van/Wagon
**1990 - 1993 (AC) Dynasty/New Yorker/New Yorker Salon**
1990 - 1993 (AG) Daytona
1990 - 1995 (AJ) LeBaron Coupe/Convertible
1994 -**1999** (AN) Dakota
1990 - 1994 (AP) Shadow/Shadow Convertible/Sundance
1991 - 1995 (AS) Town & Country/Caravan/Voyager
**1990 - 1993 (AY) Imperial/New Yorker Fifth Avenue**
1994 - **1999** (BR) Ram Pickup
**1995 - 1996 (B7) Stealth**
1998 - **1999** (DN) Durango
**1995 - 1999 (FJ) Avenger/Sebring/Talon**
1995 - **1999** (JA) Breeze/Cirrus/Stratus
1996 - **1999** (JX) Sebring Convertible
1993 -**1999** (LH) Concorde/Intrepid/Vision/LHS/New Yorker/300M
1996 - **1999** (NS) Town & Country/Caravan/ Voyager
1995 - **1999** (PL) Neon
1996 - 1997 (SR) Viper
1997 - **1999** (TJ) Wrangler
1997 - **1999** (XJ) Cherokee
1993 - 1998 (ZJ) Grand Cherokee/Grand Wagoneer
NOTE :THIS BULLETIN IS PROVIDED TO IDENTIFY THE PARTS AND PROCEDURES NECESSARY TO DEACTIVATE AIRBAGS AUTHORIZED BY NHTSA. AIRBAG DEACTIVATION IS A CUSTOMER PAY PROCEDURE, NOT COVERED UNDER THE PROVISIONS OF THE WARRANTY. THE COMPONENT PARTS ARE COVERED UNDER THE APPROPRIATE MOPAR PART WARRANTY.
DISCUSSION:
DaimlerChrysler Corporation is now offering airbag on-off switches for the selected vehicles listed above. Other applicable passenger vehicles will be announced as soon as the switches are available. The switches are packaged in a kit containing all necessary parts (except as indicated) and a detailed instruction sheet.
Under the National Highway Traffic Safety Administration's rule, consumers will be authorized for on-off switches by claiming they meet any of several criteria. Airbag on-off switches must not be installed without the vehicle owner presenting the NHTSA authorization letter. For more information concerning the authorization process and/or the authorization letter call NHTSA's Auto Safety Hotline at 1-800-424-9393.
We encourage you (dealer) to install these switches when the customer is interested in doing so and has the necessary NHTSA authorization.
PARTS REQUIRED:
NOTE :SOME INSTRUCTION SHEETS FOR THE 1999 MODELS LIST ONLY 1998 MODELS ON THE COVER PAGE. THE 1998 KITS CAN BE USED ON ALL 1999 CARRY-OVER VEHICLES.
DEACTIVATION/DOCUMENTATION PROCEDURE:
1. Before you install any airbag on-off switch for owners of air bag equipped vehicles, the owner must present to you an "Authorization Form" from the U.S. Department of Transportation National Highway Traffic Safety Administration (NHTSA), certifying the specific vehicle by its vehicle identification number. The authorization applies only to the vehicle identified and not to other vehicles that the owner may have.
2. The owner must complete the "Authorization to Install Air Bag On-Off Switch Release Agreement Form" available on T.I.L. and printed on your dealership letterhead. Keep a copy for your records and make a copy for the vehicle owner.
3. Complete the NHTSA authorization form, and return it to NHTSA within seven days, making copies for the owner's and your records.
NOTE :ALL DEALER OWNED USED VEHICLES SHOULD BE INSPECTED FOR PROPER AIRBAG OPERATION, i.e. NOT DEACTIVATED, PRIOR TO RESALE.
#40 ·
A/T - Engine Bucking/Surging at 5,300 Rpm
NO: 18-19-98
GROUP: Driveability
DATE: Apr. 10, 1998
SUBJECT:
Vehicle Bucking During Wide Open Throttle Acceleration
MODELS:
1996 - 1998 (AB) Ram Van
1996 - 1998 (AN) Dakota
1996 - 1998 (BR/BE) Ram Truck
1998 (DN) Durango
1996 - 1998 (ZG) Grand Cherokee (International Markets)
NOTE : THIS INFORMATION APPLIES TO VEHICLES BUILT BEFORE JAN 16, 1998 MDH (0116XX) EQUIPPED WITH GASOLINE ENGINES AND A 42/44/46 OR 47RE TRANSMISSION.
SYMPTOM/CONDITION:
Some vehicles may experience bucking during wide open throttle (WOT) acceleration. The bucking occurs at approximately 5300 RPM. This condition may be caused by reaching the high RPM fuel shut off rev limit before the transmission can shift into the next higher gear and is most likely to occur with high electrical loads (high beams on, heated back lite, heated seats, radio, HVAC blower on MAX etc.). During high current demands, the generator may emit electrical noise that can affect the transmission governor pressure sensor output. If this occurs, the transmission may not shift properly to the next higher gear under (WOT) acceleration conditions and therefore reach the fuel shut off rev limiter. This may be seen most often between the 2-3 shift but can also be experienced between the 1-2 shift.
DIAGNOSIS:
Using the Diagnostic Scan Tool (DRB III(R)) with the appropriate Diagnostic Procedures Manual, verify all engine/transmission systems are functioning as designed. If Diagnostic Trouble Codes (DTC's) are present, record them on the repair order and repair as necessary before proceeding further with this bulletin.
NOTE : ONLY PERFORM THE FOLLOWING PROCEDURE SAFELY ON A HIGHWAY OR ROAD OBEYING ALL POSTED SPEED LIMITS AND LAWS.
Attempt to duplicate the condition by switching on all accessory loads and driving the vehicle with WOT accelerations through a shift sequence to see if the engine will reach the fuel shut off rev limiter before the 2-3 or 1-2 shift is made.
If the bucking condition is experienced at approximately 5300 RPM before making the appropriate upshifts, switch off all electrical loads and repeat the procedure. Repeat the procedure with the electrical loads on and off a second time. If the bucking occurs with the electrical loads on and does not occur with the loads off, perform the Repair Procedure.
PARTS REQUIRED:
1 56041403AA Sensor, Governor Pressure
REPAIR PROCEDURE:
This bulletin involves installing a newly designed governor pressure sensor.
1. Following the procedures in the applicable service manual, replace the governor pressure sensor with p/n 56041403AA (Figure 1).
2. Check the throttle valve cable adjustment. Make appropriate adjustments, if necessary, following the applicable service manual procedure.
TIME ALLOWANCE:
Labor Operation No: 21-96-06-90 1.1 Hrs.
FAILURE CODE: P8 - New Part
#41 ·
Ignition System - Cross Fire/Ignition Wire Induction
NO: 18-48-98
GROUP: Vehicle Performance
DATE: Dec. 30, 1998
SUBJECT:
Ignition System
Cross Fire/Secondary
MODELS:
1994 - 1999 (BR/BE)Ram Truck
1995 - 1998 (ZG) Grand Cherokee (International Market)
NOTE :THIS INFORMATION APPLIES TO VEHICLES EQUIPPED WITH A 3.9L, 5.2L, OR 5.9L ENGINE.
AB MODELS WILL BE ADDED LATER (NEW PARTS REQUIRED).
SYMPTOM/CONDITION:
Some vehicles may exhibit one or more of the following:
Spark knock complaints when the vehicle is under load.
Various single cylinder misfire (1, 3, 7), especially 5 and/or 8.
Surge in 4th gear with the Electronically Modulated Converter Clutch (EMCC) engaged (around 45 mph).
Perceived torque converter EMCC engagement/disengagement around 45 mph.
DIAGNOSIS:
Using the Mopar Diagnostic System (MDS/MDS 2) or the Diagnostic Scan Tool (DRB III(R)) with the appropriate Diagnostic Procedures Manual, verify all engine/transmission systems are functioning as designed. If other than mentioned Diagnostic Trouble Codes (DTC's) are present, record them on the repair order and repair as necessary before proceeding further with this bulletin. If no DTC's are present or if the above symptoms/conditions have been described by the customer, perform the Repair Procedure.
NOTE :THIS REROUTING PROCEDURE SHOULD BE PERFORMED BEFORE ANY OTHER MISFIRE, SURGE, OR SPARK KNOCK REPAIRS ARE ATTEMPTED.
PARTS REQUIRED:
3 56028186 Clip, Single Wire
2 06503441 Clip, Wire To Hose (5.2L & 5.9L)
1 04364375 Convolute, 10 ft Roll
TIME ALLOWANCE:
Labor Operation No: 08-12-15-92 - 3.9L (All) 0.2 Hrs.
08-12-15-93 (ZJ) 5.2/5.9L 0.2 Hrs.
(AN/DN) 5.2/5.9L 0.3 Hrs.
(BR/BE) 5.2/5.9L 0.4 Hrs.
FAILURE CODE: 9X - Routed Improperly
#42 ·
5.2L and 5.9L Engine Procedures
1. Coil Wire Routing (Figure 1 and 2)
A. Remove the coil wire from the distributor cap coil wire tower terminal.
B. Remove the coil wire from the rear five-wire clip, the center three-wire clip, and the front one-wire clip located along the lower side of the right valve cover.
C. Install three (3) one-wire clips p/n 56028186 along the top and front of the valve cover. Use the studs of the valve cover retaining bolts (Figure 1).
NOTE :SOME APPLICATIONS MAY ONLY HAVE STUD LOCATIONS FOR 3 OF THE ONE-WIRE CLIPS.
D. Route the coil wire starting from the ignition coil toward the distributor. Any excess wire should end up at the distributor end.
E. Install the coil wire into the one-wire clips. This procedure may be easier to perform while the coil wire is loose from the valve cover (before the one-wire clips are attached to the valve cover studs).
F. Cut the ignition wire convolute p/n 04364375 into three lengths 203 mm (8 in.), 101.5 mm (4 in.), and 82.5 mm (3.25 in.).
G. Slit and install the three sections of convolute onto the coil wire between the one-wire clips. Install the 82.5 mm (3.25 in.) section at the front of the right valve cover. Install the 203 mm (8 in.) and the 101.5 mm (4 in.) sections along the top side of the right valve cover. This procedure may be easier to perform while the coil wire is loose from the valve cover (before the clips are attached to the valve cover studs).
H. Route the distributor end of the coil wire down and behind the intake manifold, in front of the oil pressure switch (Figure 2).
NOTE :THE COIL WIRE MUST BE A MINIMUM OF ONE (1) INCH AWAY FROM ANY OTHER IGNITION WIRES. THIS MAY REQUIRE THAT THE COIL WIRE BE ROUTED UNDER VACUUM AND/OR WIRE HARNESSES IN THE RIGHT REAR CORNER OF THE INTAKE MANIFOLD.
I. Route the distributor end of the coil wire up the side of the distributor cap and onto the coil wire tower terminal.
J. Position the original piece of coil wire convolute so it protects the wire against chafing with components at the rear of the engine.
2. No.8 Cylinder Plug Wire Routing (Figure 3)
A. Remove the No.8 cylinder plug wire from the distributor cap tower terminal.
B. Remove the No.8 cylinder plug wire from the five-wire clip located at the lower rear of the valve cover.
C. Route the No.8 cylinder plug wire over the rear quarter of the right valve cover (Figure 3).
D. Position the original piece convolute from the No.8 cylinder plug wire to prevent chafing at the right valve cover and with other engine components.
E. Secure the No.8 cylinder plug wire and its convolute in place with the hose to wire clip p/n 06503441. The small end of the clip is positioned over the convolute. The large end of the clip is fastened to a heater hose (A/C line on ZJ models).
NOTE :MAKE SURE THE NO.8 CYLINDER PLUG WIRE IS SECURE AND AWAY FROM THE COIL WIRE AND THE NO.4 CYLINDER PLUG WIRE. MAKE CERTAIN IT WILL NOT FALL DOWN AND CONTACT THE CYLINDER HEAD AND/OR EXHAUST COMPONENTS.
F. Install the No.8 cylinder plug wire to its distributor cap terminal.
3. No.4 Cylinder Plug Wire Routing (Figure 4 and 5)
A. Remove the No.4 cylinder plug wire from the distributor cap terminal.
B. At the three-wire clip (located at the center of the lower side of the right valve cover), keep the two wires from crossing and chafing each other. Position the No.2 cylinder plug wire in the top wire slot and the No.4 cylinder plug wire in the bottom wire slot. Leave the middle wire slot empty (Figure 5).
C. At the five-wire clip (located at the right rear lower side of the valve cover), keep the plug wires from crossing and chafing each other. Position the No.4 cylinder plug wire in a slot that will obtain the maximum amount of distance allowable from the No.8 cylinder plug wire (Figure 6). Remove any slack in the No.4 cylinder plug wire between the three-wire and the five-wire clips.
NOTE :EARLIER MODEL FIVE-WIRE CLIPS LOOK SLIGHTLY DIFFERENT BUT THE SAME WIRING LAYOUT APPLIES.
D. Route the No.4 cylinder plug wire behind the transmission dipstick tube and heater hoses. On ZJ models this may not be possible due to the location of the bulkhead.
NOTE :MAKE SURE THAT THE NO.4 CYLINDER PLUG WIRE IS, AT LEAST ONE INCH AWAY FROM THE NO.8 CYLINDER PLUG WIRE.
E. Install the No.4 cylinder plug wire to its distributor cap terminal (Figure 7).
4. No.7 Cylinder Plug Wire Routing (Figure 8 and 9)
A. Verify that the No.7 cylinder plug wire crosses over the distributor cap and leaves the distributor cap between the No.3 and the No.6 tower terminals (Figure 8). This is the original wire routing for 1998 and prior model years.
B. For 1999 M.Y. vehicles the No.7 cylinder plug wire was shortened. Reroute the No.7 cylinder plug wire so that it crosses the distributor cap and leaves the distributor cap between the No.6 and the No.5 tower terminals (Figure 9).
NOTE :MAKE SURE THE NO.7 CYLINDER PLUG WIRE IS, AT LEAST ONE INCH, AWAY FROM THE NO.5 CYLINDER PLUG WIRE.
5. No. 5 Cylinder Plug Wire Routing (Figure 10)
A. Remove the No.5 cylinder plug wire from its distributor cap terminal.
B. Remove the No.5 cylinder plug wire from the five-wire clip located at the lower rear of the left valve cover.
C. Route the No.5 cylinder plug wire over the left valve cover and in front of the breather tube elbow.
D. Position the original convolute from the No.5 cylinder plug wire to prevent chafing against the valve cover and any engine components. Secure the small end of the hose to wire clip p/n 06503441 over the convolute. Secure the large end of the hose to wire clip to the breather hose.
NOTE :MAKE SURE THE NO.5 CYLINDER PLUG WIRE IS SECURE AND AWAY FROM THE NO.7 CYLINDER PLUG WIRE. MAKE CERTAIN IT WILL NOT FALL DOWN AND CONTACT THE CYLINDER HEAD AND/OR EXHAUST COMPONENTS.
#46 ·
3.9L Engine
1. Coil Wire Routing (Figure 11 and 12)
A. Remove the coil wire from the distributor cap tower terminal.
B. Remove the coil wire from the right rear five-wire clip, the center three wire clip and the front one-wire clip on the right valve cover.
C. Install three (3) one-wire clips p/n 56028186 along the top and front of the valve cover studs (Figure 11).
F. Cut the ignition wire convolute p/n 04364375 into three lengths. Two (2) at 101.5 mm (4 in.), and one (1) at 82.5 mm (3.25 in.).
G. Slit and install the three sections of convolute onto the coil wire between the one-wire clips. Install the 82.5 mm (3.25 in.) section at the front of the right valve cover. Install the two 101.5 mm (4 in.) sections along the top side of the right valve cover. This procedure may be easier to perform while the coil wire is loose from the valve cover (before the clips are attached to the valve cover studs).
H. Route the distributor end of the coil wire down and behind the intake manifold, in front of the oil pressure switch (Figure 12).
NOTE :THE COIL WIRE MUST BE A MINIMUM OF ONE (1) INCH AWAY FROM ANY OTHER IGNITION WIRES. THIS MAY REQUIRE THAT THE COIL WIRE BE ROUTED UNDER VACUUM ANDIOR WIRE HARNESSES IN THE RIGHT REAR CORNER OF THE INTAKE MANIFOLD.
#47 ·
Memory Power Seat - Travel Range
NO: 08-44-98
GROUP: Electrical
DATE: Dec. 11, 1998
SUBJECT:
Memory Power Seat
Travel Range
MODELS:
1996-1999 (NS) Town & Country
1996-1999 (GS) Chrysler Voyager
1996-1998 (ZJ) Grand Cherokee
1996-1998 (ZG) Grand Cherokee (International Market)
DISCUSSION:
The Memory Seat/Mirror Module (MSMM) (on ZJ/ZG the module is for the seat only) detects and remembers where the end of seat travel (called "soft stop") is in each direction. A soft stop is set in MSMM memory when the position sensing feedback voltage, controlled by a potentiometer on the motor end, fails to change. The feedback voltage potentiometers vary the position sensing feedback voltage based on seat position/movement (no movement, no change in position sensing feedback voltage). The seat motor automatically stops at the soft stop on any subsequent movement so the motor does not run into a stall condition (end of travel).
The soft stop limits will be updated any time the MSMM senses a mechanical stall (such as when something is stuck under or behind the seat that causes the seat to stop moving). These soft stops can prevent the seat from being able to have memory positions set over the full range of travel. Also, positions that were previously programmed to locations beyond an updated soft stop limit will not be recalled as they are "out of range."
When a new MSMM or seat track is installed into a vehicle, the soft stops must be programmed into the MSMM memory for proper operation, the last paragraph of this TSB explains the procedure to properly set soft stops. Failure to properly set soft stops could result in intermittent memory seat operation.
There are two potential reasons for intermittent memory functioning of the seats. The first possibility is the soft stops learned by the MSMM may need to be reset. New soft stops are learned by the MSMM any time movement is restricted. (This could be as simple as hitting an obstruction in the seat's path or a person shifting their body while a power seat motor is in operation.)
The second reason only applies to NS/GS-vehicles, intermittent operation of the memory seat can be caused by a poor connection at pin 23 of the P34 connector which is located near the right side of the steering column. This circuit is used to communicate and control the seat module. This circuit "locks out" movement when the vehicle is not in park and also causes seat position recall when used with the Remote Keyless Entry (RKE) feature. The P34 connector should be inspected for fully seated and clean contacts.
To check and reset the soft stop limits in memory, use the control switches on the side of the seat to move the seat in one direction to the end of travel, then energize the seat again in the same direction until it stops and for three additional seconds after it stops. The amount that the seat moved upon the second energizing is the amount the soft stop has been reprogrammed. Repeat this procedure for each of the directions of movement (one at a time).
NOTE :IF THE SEAT TRACK ASSEMBLY OR MSMM HAVE NOT BEEN REPLACED, THIS METHOD OF SOFT STOP RESET LEAVES THE CUSTOMER'S SETTINGS PROGRAMMED IN THE MSMM (AS OPPOSED TO USING DIAGNOSTIC MODES 1 AND 2 DESCRIBED IN THE SERVICE MANUAL).
#48 ·
PCM - Light Spark Knock Condition
NO: 18-24-98
DATE: Jul. 31, 1998
SUBJECT:
Light Spark Knock
Timing Retard Feature
MODELS:
1996 - 1997 (AB) Ram Van
1996 - 1997 (AN) Dakota
1996 - 1997 (BR) Ram Truck
1996 - 1997 (XJ) Cherokee
1996 - 1997 (ZJ) GrandCherokee
1996 - 1997 (ZG) Grand Cherokee (International Markets)
NOTE :THIS INFORMATION APPLIES TO VEHICLES EOUIPPED WITH A 2.5L, 4.OL, 3.9L, 5.2L AND 5.9L LIGHT DUTY GASOLINE ENGINES.
SYMPTOM/CONDITION:
Some vehicles may exhibit light spark knock with a warm engine under load.
DISCUSSION:
Determine when the customer exhibits this condition and verify it by driving the vehicle in similar conditions. If the vehicle exhibits light spark knock with a warm engine under load perform the flash update procedure. Once the flash procedure is completed, spark advance/retard may be adjusted.
NOTE :THE DRB III(R) MUST BE OPERATING AT RELEASE 25.5 OR HIGHER.
Select DRB III(R) stand alone, current model year diagnostics, engine, and miscellaneous. When in miscellaneous, spark advance will be available. Use the arrow keys to retard timing in 20 increments to a maximum of A°. When the DRB III(R) screen reads 0 the vehicle will be set at maximum advance and when at -4 it will be set at maximum retard.
NOTE :THE IGNITION KEY MUST BE CYCLED FOR THE CHANGES TO TAKE EFFECT.
After performing the spark advance/retard feature, drive the vehicle to verify that the light spark knock is gone.
This feature will not compensate for heavy spark knock conditions. If heavy knock is experienced, funher diagnosis and testing will be required.
NOTE :WHENEVER A POWERTRAIN CONTROL MODULE (PCM) IS REPLACED DUE TO FAILURE, THE SOFTWARE OF THE REPLACEMENT CONTROLLER SHOULD BE VERIFIED FOR THE LATEST REVISION LEVEL. USE THE FLASH PROCEDURE TO UPDATE REPLACED CONTROLLERS AS NECESSARY.
EQUIPMENT/PARTS REQUIRED:
1 CH6OOO ScanTool (DRBIII(R))
1 CH7OOO/7001 J1962 Cable
1 04669020 Label - Authorized Software Update
1 04275086 Label - Authorized Modification
NOTE :THE MDS AND DRB III(R) ARE REQUIRED TO PERFORM THIS REPAIR AND THE SYSTEM MUST BE OPERATING WITH RELEASE 21 OR HIGHER AND TIL CD RELEASE 1165 OR HIGHER MUST BE INSTALLED. THE DRB III(R) MUST BE OPERATING AT RELEASE 25.5 OR HIGHER.
TIME ALLOWANCE:
Labor Operation No: 08-19-41-96 0.5 Hrs.
#49 ·
Repair Procedure
This bulletin involves selectively erasing and reprogramming the Powertrain Control Module (PCM) with new software.
1. Connect the MDS (Mopar Diagnostic System) and DRB III(R) (Scan Tool) to the vehicle and power them up.
3. Use the arrow keys and select # 2 MDS DIAGNOSTICS on the DRB III(R) MAIN MENU Screen.
4. Use the arrow keys and select DIAGNOSTIC MENU on the MDS, then press NEXT MENU.
5. Use the arrow keys and select VEHICLE CONTROLLER PROGRAMMING on the MDS, then press NEXT MENU.
6. Use the arrow keys and select PROGRAMMING OF ALL OTHER CONTROLLERS USING MDS & DRB III(R) on the MDS, then press NEXT MENU.
7. Follow the steps presented on the MDS and DRB III(R) which will allow the DRB III(R) to obtain the current part number of the PCM.
8. The MDS will display the part number of the PCM on the vehicle and the appropriate replacement part number, then press NEXT MENU to begin programming.
If the PCM on the vehicle has already been updated or programmed, a NO UPDATES AVAILABLE message will be displayed. Check the part number of the PCM on the vehicle and compare it to the part number displayed. If the POM has already been updated, then another condition exists that will require further diagnosis and repair.
9. The MDS and DRB III(R) will prompt for any operator action needed during the remainder of the programming process.
10. Type the necessary information on the "Authorized Software Update Label" p/n 04669020 (Figure 1). Attach the label to the PCM and cover the label with the clear plastic overlay.
11. Type the necessary information on the "Authorized Modification Label" p/n 04275086 and attach the label near the VECI Label (Figure 2).
#50 ·
Radio/CD Player - Erratic Channel/Track Changes
NO: 08-50-98
GROUP: Electrical
DATE: Nov. 27, 1998
SUBJECT:
Radio Station Or CD Track
Changes When Steering Wheel
Volume Switch Is Activated
MODELS:
1996 through 1998 (ZJ) Grand Cherokee
NOTE :THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH REMOTE STEERING WHEEL MOUNTED RADIO CONTROLS AND RBN AND RAZ SALES CODE RADIOS.
DISCUSSION:
Some customers may experience an intermittent condition where the radio station or CD Track could change when the steering wheel mounted volume switch is activated. This condition may be due to a communication error between the multiplexed steering column switch and the Body Controller Module (BCM). A revised BCM has been released which will filter out any erroneous signals. The new BCM part number is 56042409AF. This part is only available through the Huntsville Service Centers (Dial Function 11).
#51 ·
Roof/Sunroof - Water Leaks
NO: 23-14-97 Rev. A
GROUP: Body
DATE: Sep. 12, 1997
SUBJECT:
Roof/Sun Roof Water Leaks
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN NUMBER 23-14-97 WHICH SHOULD BE REMOVED FROM YOUR FILES. THE BULLETIN ADDS A PROCEDURE TO INSPECT FOR THE PRESENCE OF A DRAIN TROUGH ON THE SUN ROOF. THE CHANGES ARE HIGHLIGHTED WITH **ASTERISKS**.
MODELS:
1996 - 1997 (ZJ) Grand Cherokee
DISCUSSION:
Water leaks may be present causing wet carpets or water spilling from the headliner during turns or while braking. Water leaks in the roof area may be difficult to diagnose. The sun roof contains a drip trough designed to catch any water leaking from around the sun roof opening and drain it out any of four drain tubes located in the body. These tubes are routed through interior body panels and are not easily accessible. Water testing may not reveal the location of the leaks if they are performed on a level surface such as a garage floor. If one or more of the drain tubes are restricted, water will drain out the remaining tubes if the vehicle is on a level surface. The problem occurs when the vehicle is parked on an incline. If a tube on one end of the vehicle is plugged and the vehicle is parked with the other end even a few inches higher, water will over flow the trough and spill onto the headliner. The headliner will retain the water, or it will run down one of the sides and enter the passengers' compartment.
The front drain tubes are routed in the rocker panel area and the rear tubes are routed into the quarter panel area behind the wheel wells. All four tubes must be clear of any restrictions. Water can be poured into the trough with the headliner in place. Pour water into the trough and observe the under body for water to be draining out of all four locations. The absence of water in any location may indicate that one of the drain tubes is kinked or plugged.
Make sure that there are no leaks where the drain tube connects to metal tubes on the trough.
Check the roof rack screws. They should have a pre-applied thread sealer on them. If no sealer is present, apply MOPAR Lock & Seal or equivalent to the threads. If no sealer is present, a slow leak can be present and water can drip directly on the headliner.
Inspect the rear drain tube adapter in the quarter panel. This is a dual purpose adaptor. It serves as the exit point for the drain tube and as the drain for the quarter panel. Make sure that the drain is open and that the drain holes for the quarter panel are not covered by the tube or by grease used in the installation.
** The sun roof contains a drip trough or channel, which travels with the glass and is intended to catch any water that may leak at the rear of the sun roof. This trough can be damaged and break away from the mechanism. The trough is visible at the rear of the opening with the sun roof forward and up at the rear. Inspect for the presence of the trough whenever leaks are present. If the trough is not attached to the assembly, it is usually sitting inside sun roof. The trough is available as a separate part and can be replaced by removing the sun roof glass. Make sure to inspect inside the sun roof mechanism and remove the old trough if it is present.
Top
