Technical Service Bulletin Questions... - JeepForum.com
post #1 of 6 Old 01-30-2008, 04:14 PM Thread Starter
J_Minnesota
With TSB's are they covered by the warranty? I thought I was going crazy, and couldnt figure out why my suspension would "squak" when I hit speed bumps etc, but only happened generally when its cold (a lot of the time here in Minnesota). So now I see a TSB labeled 0200204a that describes this exact situation on wjjeeps.com. Do Jeep dealerships do the work for free on these?
'04 Grand Cherokee Laredo 4.0
K&N FIPK2
J_Minnesota is offline
post #2 of 6 Old 01-30-2008, 05:02 PM
Virmagicus
Virmagicus's Avatar
Here is a link. http://www.jeep.com/webselfservice/j...eenName=recall
Jeff
Virmagicus is offline
post #3 of 6 Old 01-30-2008, 05:13 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
A TSB is not a recall.
If your vehicle is out of warranty, you will most likely have to pay for it.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 6 Old 01-30-2008, 05:48 PM Thread Starter
J_Minnesota
If my vehicle is still in warranty is it covered?
K&N FIPK2
post #5 of 6 Old 01-30-2008, 05:57 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Should be. Call your dealership, describe your problem, mention the TSB.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #6 of 6 Old 01-24-2009, 02:50 PM
CTJeepWJ
2010 JK Wrangler
It takes about 15 min to do this TSB. If you have the front skid plate, it may take an extra 5 min. I did it last winter and it fixed the problem right away. i have heard that you can pull off the old ones, clean them thoroughly and regrease them. I bought new bushing, it was worth it.
Good luck with it. Let me know if you have any questions.
-Ed
-Ed
BLACK JEEP SOCIETY
2010 JK & 2004 WJ
CTJeepWJ is offline
Build Sheet & Tech Service Bulletin Q JacksonsHole ZJ Grand Cherokee Forum 2 04-13-2009 09:28 AM
Technical Service Bulletin on WK Auto Windows BigSensFan WK Grand Cherokee & XK Commander Forum 4 04-22-2008 09:46 PM
Technical Service Bulletins ? kdt1970 ZJ Grand Cherokee Forum 8 08-02-2007 07:35 AM
Technical Service Bulletins Meerkat ZJ Grand Cherokee Forum 68 09-04-2005 09:25 PM
wjjeeps/tech service bulletin paintnjeeps ZJ Grand Cherokee Forum 1 03-06-2005 05:58 PM
