Technical Question - JeepForum.com
post #1 of 3 Old 10-17-2002, 12:29 PM Thread Starter
CSinnett
Technical Question
Hi All,
I'm hoping one of you Jeep vets out there can help shed some light on a topic for me.
I have a 95 Grd Cherokee w/ the inline 6 cylinder. It idles rough, and has stalled in the past. The local dealership says its the Idle Air Control that's gone bad and is causing the problem.
When I run the self-diagnostic on the Jeep, I get codes 12 and 17.
I belive code 12 is:
"Direct battery input to PCM was disconnected within the last 50-100 key-on cycles. "
and code 17 to be:
"Engine did not reach operating temperature within acceptable limits. Engine does not reach 20 F. within 5 minutes with a vehicle speed signal."
Can anyone out there shed some light on what these two codes mean - and more importantly, what is required to fix them myself (if possible).
I can't tell if these codes are related to the IAC like the dealer says. What would be causing code 12 and 17?
Any help would be greatly appreciated. I'm hoping that I can do this work myself in the coming weeks.
Best Regards,
~ Charlie
CSinnett is offline
post #2 of 3 Old 10-17-2002, 06:38 PM
gcl97
This is what I have found:
Code Diagnostic item
17 Engine is cold too long
Check items: Engine coolant temperature sensor circuit
and connector / Engine coolant temperature sensor /
Thermostat
17 Closed loop temperature not reached (M/T)
and connector / Engine coolant sensor / Thermostat
good luck.
gcl97 is offline
post #3 of 3 Old 10-18-2002, 07:57 AM Thread Starter
CSinnett
this is exactly what I was looking for - thank you very much for this.
I replaced the IAC valve last night and that seemed to rememdy the rough idle - but I haven't checked to see if it shows a different diagnostic code yet.
The car is getting up in miles though, and I'd like to be pro-active in replacing parts. Hopefully, the engine thermostat and coolant sensor related to code 17 isn't too difficult.
Thanks again - I do appreciate it.
~cs
CSinnett is offline
technical question ZJPunk98 ZJ Grand Cherokee Forum 9 07-29-2008 01:56 PM
Technical Manual GC '06 - ? Bishop609 WK Grand Cherokee & XK Commander Forum 7 02-27-2008 03:13 PM
what is the technical name for these? mdsuave13 ZJ Grand Cherokee Forum 2 12-07-2006 09:49 AM
Technical help Paul Vachon ZJ Grand Cherokee Forum 21 08-11-2005 03:59 PM
Technical Help? Kafn8td ZJ Grand Cherokee Forum 7 04-25-2005 04:16 PM
