Tcase skid - JeepForum.com
post #1 of 13 Old 06-12-2013, 09:41 AM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Tcase skid
My trail jeep didn't come with front or t-case skids from the factory. I pulled a t-case skid expecting it to bolt up like the front skid had, but the nuts on the inside of the frame rails aren't there.
So now I've got a decision, should I find a way to mount the tcase skid I have, or if I'm going to be welding to the frame anyway should I just build a stronger one?
kg6mov is online now
post #2 of 13 Old 06-12-2013, 09:48 AM
Cherokee95kid
The t case skid used nut serts to mount all I did was get a long ratchet drive for where it mounts to the cross member there should be two holes that u can get the ratchet drive down in. Where it mounts to the rail I drilled a 1" hole on the side so I can get a wrench in there to hold a nut then I spray painted the hole and covered it with a rubber plug
Cherokee95kid is offline
post #3 of 13 Old 06-12-2013, 10:22 AM
dnuccio
I pulled the crossmember with the skid. That way I had the nutserts there. For the frame side, I just used a big *** lag bolt
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 13 Old 06-12-2013, 11:02 AM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
Well the skid is off my niner, so I don't really want to play move the xmember one jeep to the left (the teggy would get jealous and blow something).
After looking at what some people have done to their t-case skid, I'm thinking I want a bit more beef. Not gonna be driving home if I hit the tcase hard, and I'm a little heavy on the skinny pedal.
post #5 of 13 Old 06-12-2013, 11:06 AM
tucsonzj
I've wacked mine pretty good on several occasions (has the scars to prove it) and has held up very well.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #6 of 13 Old 06-12-2013, 01:09 PM
Myusername1674
ive been thinking about getting a tcase skid. Is the factory one really that good
Sent from my couch using JeepForum app
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #7 of 13 Old 06-12-2013, 01:52 PM
dnuccio
i teetered my jeep on a big rock once, right on the skid. didnt even dent it, just scratched it up pretty good
R.I.P. Ratmonkey
dnuccio is offline
post #8 of 13 Old 06-12-2013, 03:05 PM
tucsonzj
Like I said no issues for me, I haven't teetered it just a few good crashes into some big rocks lol
Sent from AutoGuide.com Free App
tucsonzj is offline
post #9 of 13 Old 06-12-2013, 03:38 PM
JohnnyZJ
swap to a 231 tcase and you won't hit anything. those stock skids are like anchors. good thing they hold up
to bad you guys are so far away, i have a couple kicking around you could have.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #10 of 13 Old 06-12-2013, 03:42 PM
tucsonzj
i'll keep my 249.
tucsonzj is offline
post #11 of 13 Old 06-12-2013, 03:49 PM
JohnnyZJ
its funny, we are gutting a 95 right now with a crap 249 (maybe whiteout will post the video later lol) and it hangs down a good 3" more than my 231. my 231 sits above the cross member. for a 'skid' i'm literally just going to bolt some flat iron across to the frame rails.
almost a 'flat belly' lol. well nowhere near like the TJs but meh, i still haven't hit it yet.
JohnnyZJ is offline
post #12 of 13 Old 06-12-2013, 10:29 PM
Myusername1674
This is so far the only reason I've considered swapping my 249. Maybe i will just get one of those skids and see how that goes.
(in progress)
post #13 of 13 Old 06-12-2013, 10:34 PM Thread Starter
kg6mov
Hears the voices
kg6mov's Avatar
The only reason I would drop my 249 is if somebody left a lunched hp30 on my doorstep. I'm not convinced, I've got some 3/16 plate I could tack up for it, or I could play swap the x-member and just tack a bolt plate to the frame. Probably end up depending on how much welding time I have. Gotta make some sliders.
