Taurus fan swap in 4.0? - JeepForum.com
post #1 of 6 Old 03-08-2009, 10:38 PM Thread Starter
redhatman
redhatman's Avatar
I read a lot about the taurus swap so I went and got one, but I guess I might have missed one key thing....will it even fit in the 4.0 engine bay? Mine does not...Anyone got this to work before or any ways around it?
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline
post #2 of 6 Old 03-09-2009, 07:15 AM
Marcos
Do you recall what the clearance issue was? I'm thinking of doing this, and it struck me that i might need to swap in an XJ water pump to gain some clearance (it stick out about 1/2" less). The only problem is, if I have to swap back, I will have to swap pumps again, as the XJ pump doesn't have provisions for fan mounting.
Marcos is offline
post #3 of 6 Old 03-09-2009, 10:05 AM
zacjeff
i put one in mine but i think it might be a different model taurus because it fit with no problems at all
4.0 I6, 30" by 9.5" dueller at's, crager soft 8's, 2" BB, home made quick discos, K&N cold air intake, ford taurus e-fan
"I say if your kid knows peanuts will kill him and he insists on stealing someone's p-butter sandwich, that's just darwin in action."
zacjeff is offline
post #4 of 6 Old 03-09-2009, 10:14 AM
gomes512
1994 ZJ
You will have do some trimming to the fan housing and I believe the water pump bolts will be awfully close or touching. Either cut/remove them and you should be able to squeeze it in there.
gomes512 is offline
post #5 of 6 Old 03-09-2009, 11:23 AM
zacjeff
yea on the fan i used the fan motor sits right below the water pump bolts so their not a problem
zacjeff is offline
post #6 of 6 Old 08-15-2011, 07:38 AM
neatus
I did this swap with a Taurus fan into my CJ. If your are good with a saw you can trim all around the shroud to make it a bit thinner and still make it look clean. I was going to use a double fan out of a Ford Contour due to them being much thinner than the Taurus fan but all the fans were missing from the Contours at my local junk yard. In any case the Contour fan might be one to look out for since they have a much slimmer profile. Make sure it is the double fan and not the single that are in some of the Contours/Mystiques.
neatus is offline
Ford Taurus E-fan? MeWJWifeZJ ZJ Grand Cherokee Forum 9 04-01-2009 10:58 AM
Taurus E-Fan Install gabrod72 ZJ Grand Cherokee Forum 5 11-25-2008 01:27 PM
Ford Taurus fan swap Casper4x4 ZJ Grand Cherokee Forum 1 07-11-2008 07:49 PM
To all taurus E-fan Installers!? jeepinjoe123 ZJ Grand Cherokee Forum 4 11-26-2007 08:16 AM
pulling a 3.8L taurus fan for e fan swap.. wiring question mdsuave13 ZJ Grand Cherokee Forum 3 09-11-2006 11:25 PM
