Takes a long time to crank before it starts - JeepForum.com
post #1 of 5 Old 11-09-2009, 06:14 PM Thread Starter
jeepman1919
I have a 1995 4.0 auto that has had a complete tune up plugs cap rotor wires distributer filters. It takes about 20 seconds of cranking before it starts. It got to be fuel related . It losses fuel pressure in the lines after 10 minutes of not running. I replaced the pump no change.
jeepman1919 is offline
post #2 of 5 Old 11-09-2009, 09:23 PM
jbreck
I'm pretty sure its an o ring in your fuel pressure regulator. You can just turn your key over a few times before you start or buy the whole assembly its not cheap. Or you could do the swampy bypass conversion. Hope this helps.
jbreck is offline
post #3 of 5 Old 11-09-2009, 09:32 PM
Mopargearhead
Did you replace the pump with a new one or a remanufactured one? I've seen some techs go through a few remans before they got a good one that actually worked. You could have a fuel injector sticking open, but that should also cause a misfire. Have you checked your fuel lines for an actual fuel leak? It's not common. but it could happen.
Mopargearhead is offline
post #4 of 5 Old 11-09-2009, 09:37 PM
WhiteOut
WhiteOut's Avatar
Check your battery connections and make sure they are not corroded. My buddy has battery terminals that are soooo bad I have to clean them once a month for him. It will start wicked for 2 weeks then go downhill until I clean them again.
WhiteOut is offline
post #5 of 5 Old 11-09-2009, 09:44 PM Thread Starter
jeepman1919
thanks guys Ill check the battery connections. the fuel pump was a new one. No fuel leaks I already checked that. whats a swamppy bypass?
4.0 ZJ takes long time to start...I'm scared one day it's not going to. PaLftr ZJ Grand Cherokee Forum 8 11-14-2009 09:10 AM
straight six takes a long time cranking before starting jeepman1919 ZJ Grand Cherokee Forum 18 08-03-2009 03:56 PM
00 WJ 4.0 Crank no start first try Starts ok 2nd time Vento98k2 ZJ Grand Cherokee Forum 9 02-03-2008 09:20 PM
Quadra-Trac II: Front takes a LONG time to engage jmack ZJ Grand Cherokee Forum 15 01-07-2008 07:29 AM
Poor Idle - Long Crank Time caharvey4 ZJ Grand Cherokee Forum 1 11-16-2005 09:44 AM
