Tail lights won't light up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Tail lights won't light up
Iron Rock Offroad products - get them from Kolak!WIN a Rough Country Forged Track Bar - ExtremeTerrain!FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 06-25-2008, 12:28 AM   #1
ww50th
I can't grt the tail lights to light up on my 2001 GC Ltd. New bulbs, no help. allother lights work fine. Where is the fuse for the tail lights? Can't find it in the owners manual. Any help appreciated.
ww50th is offline   Reply With Quote Quick reply to this message
Unread 06-25-2008, 08:43 AM   #2
Double E
2000 Laredo V8
Double E's Avatar
It may be in the engine compartment by the battey, under a black cover or near the hood release lever inside the drivers footwell area.
In my experience however, it's not the fuse, If the CHMSL (3rd light) comes on at all, the fuse is probably fine & you need to adjust the lightbulb socket to match the housing contacts. Those housings are notorious for a poor design that make you "hunt" for where the socket needs turned in order for the contacts to work. They're probably also starting to look brownish from heat. I'm probably going to get an aftermarket set when I have the next issue.
With lights on, a meter placed on the housing contatcts will tell you if you have power and where the problem is.
2000 Laredo 4.7L Selec-Trac. 177K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 4X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X), new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side, new Durango alternator. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote Quick reply to this message
Unread 06-25-2008, 09:38 AM   #3
Neongirl4ever
I am having the same thing going on with mine. I was beginning to wonder if it was a electrical issue. I was planning on replacing my tails with aftermarkets hoping it would work but if you say that its just the tails are a poor design, thank god. Cause i was scared getting aftermarkets wouldnt work. So i guess Im going to be off looking for new tails. Thanks!
2002 Black WJ 4.7L H.O
Quadra Drive
Is repairing considered a modification?
Neongirl4ever is offline   Reply With Quote Quick reply to this message
Unread 06-25-2008, 11:13 AM   #4
veddderman123
I had a similar problem. Found out one of the sockets was smashed in kind of weird. and the connection pionts were touching in the wrong place. It acted like a short for a long time, some times it worked and some times it didn't. Eventually it blew my fuse. I was in denial because I looked at the fuse and it looked ok. But after lots of wasted time I decided to stop by the auto store and get some fuses. I replaced it just out of not knowing what else to do and it worked!
SO then, I removed the smashed socket and arranged the sockets to where I now have turn signals and a brake lights. I'm still missing the whole socket for one of my reverse lights. I guess I either have to by after markets or go to the stealership.
Hopefully this will help. http://wjjeeps.com/fuses.htm
mine was clearly marked on the fuse box.
2000 WJ Grand Cherokee
4x4 4.0L IRO 3" lift, DT8000 shocks, Quicker Disconnects and Tenneco HD SS.
265-75-16 Cooper A/T
1982 DJ-5L Postal AMC General. Total stock and delivering the mail! :)
veddderman123 is offline   Reply With Quote Quick reply to this message
Unread 06-26-2008, 11:29 PM   #5
ww50th
Well thanks for the suggestions. My third brake light works fine. I also found a fuse under the hood (50A) that I checked with a meter and it is fine. All three of the sockets and bulbs (3157) are the same so I swapped them around to see if it was a bulb or a socket. No help. I paid special attention to the tail/brake light socket to insure that the double contacts on the socket were mated up to the double contacts on the housing. Still no tail lights. I am not getting a good power signal on my meter for the tail light power. Without a wireing diagram I'm at a loss as to where to look next.
Unread 06-27-2008, 03:31 AM   #6
theksmith
2003 WJ
check that the ground is good... perhaps both the left/right lights share a frame ground connection that is bad somewhere
i think the solid black wire at the rear lamp connector is the ground
UPDATE: its is the black wire, pin 5... and all the rear lights share a common ground that connects strangely enough to the body up near or under the front passenger seat
theksmith is offline   Reply With Quote Quick reply to this message
Unread 06-27-2008, 05:53 AM   #7
georged
Bend the contacts in the housing and the sockets so they make contact. Also put some dilectic grease on all the contacts.
georged is offline   Reply With Quote Quick reply to this message
Unread 06-27-2008, 11:09 PM   #8
ww50th
If there is a common ground for all the lights through pin 5 to the frame then this can't be the problem as all the other lights work fine. It's just the tail lights that don't work. I will try bending the contacts on the housing next. How could both side tail light contacts need adjusting? This is a very odd problem. Normal common sense troubleshooting has provided no results. 1. Fuse intact with meter and third brake light works. 2. Swapped known good bulbs and sockets with no help. 3. Ground intact as all other lights function normal with common ground. 4. There is a 12 volt power source to that socket for the brake light and it works normal. 5. There is a lack of 12 volt power source to the same socket for the tail light bulb and neither side tail light works.
Unread 06-27-2008, 11:56 PM   #9
ww50th
It gets worse. I have power to pin 4 on the lamp housing connector with the headkights on. It's the green and red wire. I have continuity from pin 4 on the housing to the single terminal under the housing for the socket. I have continuity from the single pin on the socket through the bulb. I have continuity from the double pin on the socket to pin 5 (ground) in the housing. There is absolutely no reason that the tail light bulb should not light. If I have to thak this thing to the dealer for this problem and he finds something stupid I will loose it. I'm still open to any other suggestions. Oh by the way, while I had this all apart, I carefully bent the socket and housing contacts to insure a good mating surface and then applied dielectric grease to all three contacts on every socket. Still no tail lights on either side with all other rear lights working normal. Perplexed to say the least. I've never owned a car that I couldn't get the lights to work on.
Unread 06-28-2008, 05:45 AM   #10
theksmith
2003 WJ
sorry, from your first post i thought you meant the ENTIRE tail-light assembly wasn't working but all other lights on the vehicle were
Unread 08-12-2008, 09:41 AM   #11
ww50th
I'm still fighting this tail light problem. I need access to a wiring diagram. The tail lights, license plate light, radio clock, A/C panel lights, & console lights are not working. Is there anywhere that I can view a wiring diagram for the light circuit for a 2001 Jeep Grand Cherokee Limited? Something has to be common to all of these ligh issues.
Unread 08-12-2008, 06:42 PM   #12
ratmonkey
R.I.P.
ratmonkey's Avatar
the circuit board in the housing fails on every single wj at some point, if you can't get it to work by adjusting the socket, and you've confirmed your bulbs are good, then you need to get a new housing. only one bad housing will cause all sorts of different problems with both sides.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 08-12-2008, 09:24 PM   #13
ww50th
Thanks ratmonkey for the responce. I'm still asking a very simple question that someone from the Jeep world should be able to answer but so far no help. WHERE CAN I FIND A WIRING DIAGRAM TO TROUBLE SHOOT THIS PROBLEM WITH!!!!
Unread 08-13-2008, 06:19 AM   #14
ratmonkey
R.I.P.
ratmonkey's Avatar
you're gonna need to look at the circuit board and trace out the paths if you want to fix it. you'll either see a crack, bad solder joint, or most likely a burnt area. the wiring outside of the housings is likely still in perfect shape.
Unread 08-13-2008, 07:42 AM   #15
LaCeS OuT
1994 ZJ
Go pick up a Haynes or Chilton for about $15. They have wiring diagrams. Or you can purchase a FSM (Factory Service Manual).
Jeep Sold! 02/2009
Need AMSOIL? Click Here!
LaCeS OuT is offline   Reply With Quote Quick reply to this message
