Tail Light Issues...... - JeepForum.com
post #1 of 8 Old 03-21-2005, 06:09 PM Thread Starter
Phathead
Hello everyone I am a total Jeep newbie....but I just bought a 1998 5.9 Limited with 66,000 miles and I absolutely love it......Here is my issue...
The other day I am driving to work and the Vehicle Information Center Display says "Rear Lamp Failure"....Like I said this is my first vehicle with all these cool bells and whistles....so I change the rear bulbs for my taillights....pretty easy...I check everything out....all lights appear to be working....but the Display still reads "Rear Lamp Failure". I check the owners manual, and it says that once the bulbs are replaced the system should automatically reset on the next startup.....this is obviously not happening....
Anyone have any experience with this.....?? Is there some sort of reset that I don't know about??? Any help is greatly appreciated...this is just a tad bit annoying....
Thanks in advance...
Phathead is offline
post #2 of 8 Old 03-21-2005, 06:29 PM
jeepholic
jeepholic's Avatar
I am guessing you have the wrong bulb some where, make sure that all bulbs including the third barke light have the right bulb as stated in the manual I never had.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #3 of 8 Old 03-21-2005, 06:32 PM
greasefingers
greasefingers's Avatar
1994 ZJ
If all checks out fine, then disconnect the battery.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 8 Old 03-21-2005, 06:32 PM
CaliforniaJeep
CaliforniaJeep's Avatar
I had that problem and it turned out that 1 bulb in the third brake light was out. Have someone press the brakes for you to see if one is out
-Johnny-
~Updating~
CaliforniaJeep is offline
post #5 of 8 Old 03-21-2005, 10:14 PM
haus409
Yep, mine was the same way. I drove my ZJ for a year and a half looking at that "Rear Lamp Failure" when I knew darned good and well all my lights were working. Then one day I find this site called Jeepforum.com, find the info, check my bulbs and find that one of my brake lights was wrong. Annoyance solved for $1.50 and 5 minutes work!
haus409 is offline
post #6 of 8 Old 03-22-2005, 04:46 AM Thread Starter
Phathead
Thanks for all the suggestions.....I'll go back through and check it out.....Thanks again...
Phathead is offline
post #7 of 8 Old 03-22-2005, 02:33 PM
kayla
Quick suggestion :
My 5.9 did the same thing, all lights were working.....open the liftgate and *****slap the 3rd brake light. It's been 4 months and it hasn't happened again. Seriously.
Rich-
kayla is offline
post #8 of 8 Old 03-22-2005, 02:43 PM
Mustang
Did you check the lights around the licenses plate on the back of the car this same thing happened to me. I replaced the small light and now every thing fine.
Mustang is offline
Brake light works; tail light doesn't manofmany ZJ Grand Cherokee Forum 9 08-20-2012 10:50 PM
tail light not working - brake light does work gd929 ZJ Grand Cherokee Forum 2 06-17-2010 12:29 AM
2006 Grand with 5.7L head and tail light issues Commando81 WK Grand Cherokee & XK Commander Forum 0 12-04-2009 09:25 AM
Tail Light Issues! Replaced Bulbs Problems Still Present bigtimemax ZJ Grand Cherokee Forum 4 10-28-2008 08:49 AM
Tail light issues...need advice LLmister ZJ Grand Cherokee Forum 5 03-11-2007 01:40 PM
