Tachometer spike - JeepForum.com
post #1 of 3 Old 04-02-2013, 12:58 AM Thread Starter
dean477
Tachometer spike
Hey guys, i tried a search with no luck. Occasionally my tach will spike up 500-1500k rpm with no change in the actually engine speed. It happens only for a moment and sometimes happens when going over a bump while accelerating(or maybe its just coincidence) but is not due to the tires spinning in any way.
If anyone has experienced this or has any help on the issue id really appreciate it. My pcm has the connector issue that causes a stall but i have had a good temporary fix for awhile, just adding that in incase it might be a known cause.
Thanks,
Dean
dean477 is offline
post #2 of 3 Old 04-02-2013, 07:11 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Gauge, crank sensor, wiring for crank sensor, or computer.
Start with the gauge calibration/test mode. Hold down the trip button on the cluster, turn the key from off to on to off to on to off then on and leave there. Gauges will all run through their motion when the trip button is released.
ratmonkey is offline
post #3 of 3 Old 04-02-2013, 07:23 PM Thread Starter
dean477
I will try that in a few minutes, I put in a new crank sensor about 6 months ago while trying to deal with stalling problems. It is Mopar.
dean477 is offline
