t-case swap - JeepForum.com
post #1 of 7 Old 03-04-2007, 09:09 PM Thread Starter
rustycherokee18
t-case swap
So after wrecked my transfer case this weekend its time for a swap. So what do yall recommend on the case i should use????? and what needs to be done to use that case?
rustycherokee18 is offline
post #2 of 7 Old 03-04-2007, 09:23 PM
BigItalianBeast
use the NV 242....http://jeephorizons.com/tech/tcase.html
Josh
1999 WJ 4x4 Laredo
I-6/4.0, 255/70/18 JKs, 2" BB
OME Steering Stabilizer, FMS40,Pioneer 4900 DVD, 15% Tint, Subs
BigItalianBeast is offline
post #3 of 7 Old 03-04-2007, 09:32 PM
anticrombie
anticrombie's Avatar
I'd use a 231, you don't have 4wd part time, but the case is stronger. Nothing needs to be done, only installing it and hooking up the linkages.
Charlie
anticrombie is offline
post #4 of 7 Old 03-04-2007, 10:04 PM Thread Starter
rustycherokee18
Do i need an SYE or nething on this t-case. I actually have one in my garage. So what do i need? What should i do or check over on the donor case before i put it in??
post #5 of 7 Old 03-04-2007, 11:50 PM
Trouble Maker
reckless endangerer
Trouble Maker's Avatar
Actually with the 231 you don't have 4wd fulltime.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline
post #6 of 7 Old 03-05-2007, 08:53 AM
anticrombie
Ah, thats what I meant. I do several things at once when I'm on here.
Charlie
post #7 of 7 Old 03-05-2007, 09:08 AM
jfowlzj95
Wont need an SYE if your rear driveshaft still has the slip yoke, wouldnt hurt to put one in but then you will also have to extend your rear shaft some. Just make sure your donor case is 23 spline and once you pull your current case make sure the input gears are the same lengths, if not swap them.
jfowlzj95 is offline
t case swap JeepIJoe ZJ Grand Cherokee Forum 1 07-15-2009 10:58 AM
231 T-case Swap highlyuncntered ZJ Grand Cherokee Forum 14 01-27-2009 07:10 AM
t-case swap joeyschribar ZJ Grand Cherokee Forum 2 03-04-2006 05:20 PM
NP 249 NP 242 Swap 94 ZJ 5.2 Trans Case swap / repair? smkarner ZJ Grand Cherokee Forum 1 09-27-2005 05:28 PM
242 vs 249 t-case swap xj51 ZJ Grand Cherokee Forum 3 12-09-2004 07:32 AM
