t-case swap - JeepForum.com
post #1 of 3 Old 03-04-2006, 12:34 AM Thread Starter
joeyschribar
t-case swap
hey there, would a transfer case fit from a 2000 grand cherokee, 4.0 litre, fit on my 1994 zj, 5.2v8 (np249)?
joeyschribar is offline
post #2 of 3 Old 03-04-2006, 05:33 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
It would, but you'd loose your speedometer. WJ's use parts from their ABS system to get the reading, instead of a gear in the transfer case like ZJ's do. I'd look around for one from an XJ or ZJ.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #3 of 3 Old 03-04-2006, 05:20 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Also, there is some deal with the bolt pattern. Might want to check it out. There is compatability issues when you are going from 42RE WJ to a 45RFE WJ. I would imagine that their would be an issue with a TC behind a 45RFE (V8 WJ) going to a ZJ.
Just a heads up
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
t case swap JeepIJoe ZJ Grand Cherokee Forum 1 07-15-2009 10:58 AM
231 T-case Swap highlyuncntered ZJ Grand Cherokee Forum 14 01-27-2009 07:10 AM
t case swap wheelchairman ZJ Grand Cherokee Forum 6 08-13-2006 03:23 PM
NP 249 NP 242 Swap 94 ZJ 5.2 Trans Case swap / repair? smkarner ZJ Grand Cherokee Forum 1 09-27-2005 05:28 PM
242 vs 249 t-case swap xj51 ZJ Grand Cherokee Forum 3 12-09-2004 07:32 AM
