t-case/speedo issue - JeepForum.com
post #1 of 8 Old 08-26-2013, 06:09 PM Thread Starter
worsrider4047
t-case/speedo issue
So on my niner, I replace the t case with a 242 about 2 years ago, over the weekend I replaced that with a 231 out of a 93 Cherokee, everything is in and bolted up. So on my test drive the speedo didn't work and it wouldn't shift out of 1st gear
About a year ago I got a code for output shaft sensor, but being everything worked I didn't do anything about it, im still getting the code after the swap so I got a new sensor that goes on the output of the case, that still didn't work
Any thoughts on the issue? I'm quite puzzled (I do have another sensor on order in case the first one I got was bad )
worsrider4047 is offline
post #2 of 8 Old 08-26-2013, 06:22 PM
newfieZJ
You sure it's not the trans output speed sensor you need ? What code ?
I would first try removing it and cleaning it . it's a magnetic pick up type . They get plenty stuck to them . I always just clean them when doing a fluid change . Beware , you will loose fluid removing this sensor IIRC
newfieZJ is offline
post #3 of 8 Old 08-26-2013, 06:48 PM Thread Starter
worsrider4047
I did pick one up, haven't put it in yet but I'll try to clean it before I replace, still strange to me that it worked that morning but not that night after the swap
post #4 of 8 Old 08-26-2013, 06:59 PM
newfieZJ
Strange ? Not really . Lets assume this sensor is dirty , signal could get impaired intermittently/partially . If it sat it might pick up more and stop working .
What was the code ???
Just so we are clear
Trans speed sensor in the trans overdrive unit
speed sensor on the t-case
newfieZJ is offline
post #5 of 8 Old 08-26-2013, 07:10 PM Thread Starter
worsrider4047
The code was for the output shaft sensor
post #6 of 8 Old 08-26-2013, 08:14 PM Thread Starter
worsrider4047
I cleaned it and it now shifts, but still no speedo
post #7 of 8 Old 08-26-2013, 09:16 PM
newfieZJ
Great , 1 down , one to go .
You tried a different speed sensor correct ? You may have it indexed incorrectly . 2 settings only so I would try to reclamp it in the other setting . Unclamp , turn the sensor , reclamp .
newfieZJ is offline
post #8 of 8 Old 08-26-2013, 09:24 PM Thread Starter
worsrider4047
Ha I bet that's it, I'll try tomorrow after work and let you know the answer, thanks again for the help
