T-Case issue? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > T-Case issue?
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectRIGID LED Light Blowout Sale - All Sizes, All Series, all Toxic Brakes - 3000 PSI Braided Stainless Steel Brake Line
Unread 05-29-2015, 02:09 PM   #1
thetammon
T-Case issue?
Hey guys, I'm having T-case issues. (42re with 249)
In 4 High it (the tcase?) grinds in park, reverse, drive, etc. and the jeep will not move when I give it gas. The grinding goes away when I put the tcase into 4low and the jeep will move again. Besides checking the linkage, is there anything else that it could be?
thetammon is offline   Reply With Quote Quick reply to this message
Unread 05-29-2015, 02:18 PM   #2
tjcustomranger
Have you checked linkage? It sounds like its not engaged into 4 hi
tjcustomranger is offline   Reply With Quote Quick reply to this message
Unread 05-29-2015, 02:27 PM   #3
thetammon
not yet, I haven't had a chance, Just curious to see if there's anything else that would cause this issue
Unread 05-29-2015, 02:31 PM   #4
tjcustomranger
Mine was grinded really bad one time when i had just taken it out of 4 lo to put it in 4 hi. I went to go into park it grinded like hell so i through it back in neutral and it was the tcase handle not pushed all the way up
Unread 05-29-2015, 02:36 PM   #5
kg6mov
Hears the voices
kg6mov's Avatar
Either the linkage is way out of adjustment or you've cooked the range fork inside the case.
I would try disconnecting the linkage from the case and shifting it directly from the shift tab, if that doesn't get you driving then you'll need to drop the case.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is online now   Reply With Quote Quick reply to this message
Unread 05-29-2015, 03:41 PM   #6
thetammon
cool. hopefully it's just the linkage. i don't want to have to drop it tc
Unread 06-17-2015, 10:58 PM   #7
thetammon
I pulled out the tcase. Tore it apart. Fork was trashed. Decided it was time to swap in a 242... I'm half way there anyway! Picked up a 242 in amazing condition for only $200! + ($50 core) Just need to get the correct input shaft, the one in the 249 has the early gear cut so it wont fit in the 242 properly. Luckily the place I got the tcase (FNJEEP... literally the best place I know to get used jeep parts for cheap) should have one I'll jsut trade them the one out of the 242
