T-Case fluid - JeepForum.com
post #1 of 7 Old 07-29-2009, 04:34 PM Thread Starter
stageninja
That Rigger Guy
stageninja's Avatar
T-Case fluid
Lucas Gear Oil states on the bottle that it is "excellent for Transfer cases". Would this be the case for the 249? My 249 is in great shape as it is with 140,000 miles. The reason I ask is I have tranny fluid on the tranny and the T-case. I would like to isolate the leak as there isn't enough leaking to show on the dipstick or drop the level in the t-case. It seems to only be a drop a day just hanging from each component. I know it is a seal, just want to know if it is one the other or both by, using a fluid of a different color in the T-case but I certainly don't want to prematurely ruin the VC.
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
post #2 of 7 Old 07-29-2009, 04:45 PM
Bama_WJ
Bama_WJ's Avatar
I think your only suppose to use a special Mopar fluid in your 249. Someone correct me if I'm wrong.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #3 of 7 Old 07-29-2009, 05:22 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
atf+4 only in the 249.
i tend to shy away from lucas everything these days.
take a picture of the drips and post it. i'd put money on it being the tranny output seal.
ratmonkey is offline
post #4 of 7 Old 07-29-2009, 06:22 PM
gomes512
1994 ZJ
Yep fluid as stated above, although technically I think both the 249 and 242 would be able to run olive oil in a jam.
However, gear oil is a different story. There are other transfer cases that do call for gear oils in other manufacturers but the 249 and 242 definitely don't. Low viscosity is the name of the game.
gomes512 is offline
post #5 of 7 Old 07-29-2009, 08:37 PM
sandman
from my understanding chain driven t-cases usually recomend ATF and gear driven cases call for gear oil. im not sure why and youd probably be fine running just about anything in the early ZJ (not WJ) cases but i would still stick with atf4.
Lucas stuff is pretty thick right? if so it may be too thick for the pump. just a thought.
1993 Jeep ZJ. 4.0
sandman is offline
post #6 of 7 Old 07-29-2009, 09:05 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the gear cases rely on the gears to move the fluid around, chain cases use an oil pump on the output. the oil pumps can not move a fluid as thick as gear oil.
post #7 of 7 Old 07-29-2009, 09:23 PM Thread Starter
stageninja
That Rigger Guy
stageninja's Avatar
Thanks, That's the info I am looking for. Since it isn't draining the aforementioned components I am not thinking about tearing into anything. Just trying to isolate. As far as Lucas is concerned... I don't use it for everything but where I can, I try to use it, as almost two years of income was from working on the construction, and now continuing to do production work at Lucas Oil Stadium.
T-Case fluid not right reneveah ZJ Grand Cherokee Forum 11 08-20-2008 09:11 PM
t-case fluid sandman ZJ Grand Cherokee Forum 3 10-07-2007 05:21 PM
T-case fluid zjmudder ZJ Grand Cherokee Forum 12 08-05-2005 07:54 AM
Synthetic ATF, Transfer Case Fluid, Diff. Fluid shel3702 ZJ Grand Cherokee Forum 1 07-05-2004 08:21 PM
T case fluid Ross WJ Grand Cherokee Forum 2 04-10-2004 11:56 PM
