T-case fluid - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > T-case fluid
DIY tube fender kitsAmsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Unread 08-03-2005, 12:23 PM   #1
zjmudder
T-case fluid
wondering what kind of fluid goes into 249 thanks??
96 ZJ V8 5.2L
3.5" Tuff Country soon!!
Flowmaster Super 40 w/tail pipe cut off
Undecided for tire size any suggestions would be nice
zjmudder is offline   Reply With Quote
Unread 08-03-2005, 12:25 PM   #2
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
ATF+3...
2013 FR-S
BlaineWasHere is offline   Reply With Quote
Unread 08-03-2005, 12:27 PM   #3
zjmudder
do i have to get in from the dealer or can i get it from any old automoblie place??
96 ZJ V8 5.2L
Unread 08-03-2005, 03:02 PM   #4
spuddybuddy
According to the owners manual for my 97 ZJ, I cna put in ATF or Dexron III Mercon. Is this wrong? Its got the dexron in it now and seems ok (driven ~100 miles). This is a 242 transfer case btw.
You can buy the fluid at most any autoparts store.
Sorry for the slight thread hijack =]
TIA
'97 ZJ Laredo
- 4.0L
- 176K, runnin like a champ
'06 G35 Coupe 6MT
- A bit faster than the ZJ
spuddybuddy is offline   Reply With Quote
Unread 08-03-2005, 03:05 PM   #5
zaq123
1941 JK Wrangler
TIA
Can't go wrong with whatever owners manual says.
zaq123 is offline   Reply With Quote
Unread 08-03-2005, 03:27 PM   #6
Phil Gerard
Former Mod
Phil Gerard's Avatar
Heck when I did my 249>242 TC swap - George at Transfer Cases Unlimited put in AMS 5W30 oil. And he knows more about TCs than just about anyone!
But I'm not sure I'd do that with a 249.
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline   Reply With Quote
Unread 08-03-2005, 04:50 PM   #7
BlaineWasHere
BecauseRacecar
Phil
No kidding... the 249 is a lot more picky than the 242... Hell my 247 has its own fluid...
2013 FR-S
Unread 08-03-2005, 10:18 PM   #8
Meerkat
TIA
It's not wrong, but here's what I do: my XJ with AX15 tranny uses Dexron in the tranny, so I use Dexron in the TC, my ZJ with the 42RE uses ATF+ so I use ATF+ in the TC as well. By using the same fluid in the TC as the transmission uses, I manage to minimize my confusion factor and keep the right fluids on hand.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline   Reply With Quote
Unread 08-03-2005, 11:15 PM   #9
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Warren, I thought the 42RE was the tranny that was behind the I6's... for a 96' 5.2 shouldn't it be a 44RE?
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote
Unread 08-04-2005, 08:03 AM   #10
Scottso699
Scottso699's Avatar
2006 WK
I also use 5w50 i my np242 - was told it will keep everything including the slip yoke happier - works great! 5.2 V-8s can have a 44RE or 46RH (A-500) and 5.9s have a 46RE (A-518)
Scott
2006 WK Overland - K&N CAI, Superchips Programmer, Dynomax Ultra Flo Muffler, 180 Degree Thermostat, 255/75r17 BF Goodrich M/T Tires, 1.25" Wheel Spacers, Resonator Delete, OME HD Lift
1998 ZJ 5.9L Limited - SOLD - Pictures
Scottso699 is offline   Reply With Quote
Unread 08-04-2005, 08:02 PM   #11
Meerkat
Tim, good catch, it is the 44RE on the 5.2, but the 4.0 XJ (95 Cherokee) does us the AX15.
People my age have no business trying to work from memory, but I'm just too tired to look it up.....
Warren
Unread 08-04-2005, 08:57 PM   #12
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
No sweat Warren, you are still a priceless aspect of this forum
KD8EBC
'94 ZJ 5.2 LTD
Unread 08-05-2005, 06:54 AM   #13
Rcher
What do you guys think about using Mobil 1 synthetic transmission fluid in the TC??
1998 ZJ 5.2
[B][COLOR=White][FONT=Century Gothic]White Jeep Club #7734[/FONT][/COLOR][/B]
Rcher is offline   Reply With Quote
