Symptoms of a bad transmission mount - JeepForum.com
post #1 of 6 Old 04-18-2010, 09:03 PM Thread Starter
frankie_b11
Hey Gang,
I have a question. What are the symptoms of a bad trans mount? When I have her in gear and stopped at a light I get a lot vibration in the car. Driving is fine not troubles there.
Thanks
frankie_b11 is offline
post #2 of 6 Old 04-18-2010, 09:07 PM
bigbill888
Could be motor mount and/or tranny mount.
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #3 of 6 Old 04-18-2010, 11:26 PM
ZJ5point2GCL
vibrations at a stop light could also be a bad transmission, thats what my first jeep did right before the trans exploded (2 days after i bought it)
but in OD on the highway you would get a "rumble" if the trans mount is no good
you should also be able to visually tell if its bad or not
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #4 of 6 Old 04-19-2010, 10:38 AM Thread Starter
frankie_b11
I have felt the vibrations for some time now. I also have a rough idle so it is hard to diagnose. I am pretty sure the tranny is fine. I have a 97 zj with 157,000 miles.
post #5 of 6 Old 04-19-2010, 10:40 AM
CrazyIvan888
What RPM are you idling at when you get the vibes?
Jeep: Every adventure is a repair, every repair is an adventure!
CrazyIvan888 is offline
post #6 of 6 Old 10-22-2010, 11:09 AM
DuffmanJC2000
2000 FSJ Cherokee
Check the rear exhaust hanger. Mine was dry rotted and it caused alot of vibration when i would stop. It was like a deep rumble. only costs like 7 bucks at pepboys
DuffmanJC2000 is offline
ZJ transmission mount bushings? FortCollinsZJ ZJ Grand Cherokee Forum 3 08-25-2009 01:53 AM
Transmission mount maybe? sid23man ZJ Grand Cherokee Forum 2 01-09-2009 08:46 AM
Transmission mount. Windowsrookie ZJ Grand Cherokee Forum 0 03-05-2008 07:12 PM
Transmission Mount ron semko ZJ Grand Cherokee Forum 9 06-19-2006 11:56 PM
Transmission Mount Tmaxx ZJ Grand Cherokee Forum 2 05-27-2005 09:21 PM
