Sweet and Cheap grill mod. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Sweet and Cheap grill mod.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 01-21-2015, 03:53 PM   #1
94ZJALLDAYZS
1994 ZJ
I was trying to find a grill that gave my zj some attitude and it doesn't seem make any kind of product that did my zj justice. So I made my own custom grill. Got black rustolum spray paint and clear coat. 5/16 bolts. And the backing of the grill around 20 total invested. Cheap and sick looking mod. Let me know yoir opinions.Enjoy!
Thanks-Alex
94ZJALLDAYZS is offline   Reply With Quote Quick reply to this message
Unread 01-21-2015, 04:00 PM   #2
kg6mov
Hears the voices
kg6mov's Avatar
Wow! Unique AND Creative.
Some other versions:
http://www.jeepforum.com/forum/f13/z...ctures-854533/
http://www.jeepforum.com/forum/f13/s...93/index2.html
http://www.jeepforum.com/forum/f13/1.../#post16458337
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 01-21-2015, 04:12 PM   #3
tshoeniner
That is another one to add to the list. I think that is the best looking grill I have ever seen from all cars. Great job. What kind of bolts did you use and did you pre-drill holes?
5.9 Limited slow build. 2inch BB and 265/75r16 IROK NDs.
tshoeniner is offline   Reply With Quote Quick reply to this message
Unread 01-21-2015, 04:14 PM   #4
Bodybuilder21
Is the mesh one piece behind the entire grille or individually cut?? I dig the bolts too..they'd match my pro comp wheels!!!
-96' zj -DD
-04' honda cbr 600rr -DD
-01' bmw 328i..5spd-gone
-99' xj..5spd-totaled
Bodybuilder21 is offline   Reply With Quote Quick reply to this message
Unread 01-21-2015, 04:32 PM   #5
94ZJALLDAYZS
1994 ZJ
Bolts are 5/16 in x 3-1/2 coarse thread stainless steel hex bolts. The back mesh was 2 pieces until I welded it lightly. You do have to trim the back plastic behind the grill just a tad and wire cut were the three tabs go down into the plastic.
Unread 01-21-2015, 04:32 PM   #6
94ZJALLDAYZS
1994 ZJ
Weld marks not visable.
Unread 01-21-2015, 04:56 PM   #7
coralman
I can wish can't I?
coralman's Avatar
Gotta have two antlers
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is online now   Reply With Quote Quick reply to this message
Unread 01-21-2015, 05:30 PM   #8
94ZJALLDAYZS
1994 ZJ
I did have two....until someone stole one right off my jeep
Unread 01-21-2015, 05:49 PM   #9
stormer1092
1994 ZJ
I did this. But I went the other way with the expanded steel. Also different mounting method.
Quote - I currently have this set up with some ok shocks. Mine rides stiff but its not completely unbearable. My rear end is what kills me more than anything. Signed - Okie_Rider
stormer1092 is offline   Reply With Quote Quick reply to this message
