Swaybar bushings - JeepForum.com
post #1 of 13 Old 04-04-2013, 10:35 AM Thread Starter
just_urd
Swaybar bushings
New to the forum, well I've been on but haven't participated much. Does anyone know why the sway bar/bushings are different in diameters? I can understand between a 2wd and 4wd, but I've been hearing there is up to six different diameters. I drive a 98 limited 5.2 4x4...
just_urd is offline
post #2 of 13 Old 04-04-2013, 10:37 AM
WhiteOut
WhiteOut's Avatar
IIRC yours will be 25mm or 26mm
WhiteOut is offline
post #3 of 13 Old 04-04-2013, 11:00 AM Thread Starter
just_urd
Thank you. Just trying to narrow it down so it will make my trips to napa less than three times for the same thing.
just_urd is offline
post #4 of 13 Old 04-04-2013, 11:42 AM
baldygo
go on there website and get the part # so when you go to napa
you can run in and run out with no problems or searching for the part
baldygo is offline
post #5 of 13 Old 04-04-2013, 01:53 PM
zjosh93
Why not just measure your bar? If you don't have a micrometer (overkill) or a caliper you can use an adjustable wrench. Adjust the wrench unti it just slips over the bar and measure the gap between the jaws.
zjosh93 is offline
post #6 of 13 Old 04-04-2013, 02:06 PM Thread Starter
just_urd
Good call, never thought of using an adjustable wrench. Thanks.
just_urd is offline
post #7 of 13 Old 04-04-2013, 04:38 PM
dusterdude
My 96 limited 4.0 has a 26
dusterdude is offline
post #8 of 13 Old 04-04-2013, 09:49 PM
diirkd
bad bushings
Just replaced the two Bushings that attach to the frame on my 94 ZJ. Ended up being 26mm but the guy at Oreily went outside and measured it for me before i bought it. Now to get my Front end Alligned and be Done with the squirlyness
diirkd is offline
post #9 of 13 Old 04-05-2013, 12:27 AM Thread Starter
just_urd
Well, if anyone will go out and measure the sway bar for me, they just made a sale... I'll buy the links too. I gotta Vegas trip next week, and the clunking is annoying. It'll probably still clunk after I change everything out. Gotta love a zj.
just_urd is offline
post #10 of 13 Old 04-05-2013, 11:48 PM Thread Starter
just_urd
They ended up being a 26. Swapped them out no problem.
just_urd is offline
post #11 of 13 Old 04-06-2013, 07:23 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I hope you greased them. If not, they will squeak and drive you nuts.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #12 of 13 Old 04-06-2013, 09:09 AM Thread Starter
just_urd
Sure did, thanks. Even if I didn't grease them, it would just be yet another mild squeak this beauty produces. It's soothing in a way.
just_urd is offline
post #13 of 13 Old 04-06-2013, 11:54 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Non greased aren't a mild squeal.
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
