Sway Bar link install help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Sway Bar link install help!
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 05-18-2008, 01:20 PM   #1
JZWIRKO
Hi everyone, I was recently looking under my car and noticed the the sway bar link totally dismantled and the ball was not attached into the socket anymore. I went to a local auto parts store and bought a replacement, and had everything go OK until I tried to screw the nut into the top to fasten the link. When i was screwing the nut, it seems that the nut was stuck and it not turns with the ball inside the socket. I was wondering if anyone's got any help for me so I can tighten this nut so it stops spinning with the ball.
Theres a link to a part below if anyone can help me with some installation tips.
http://www.autopartswarehouse.com/de...QQJ283901.html
Thanks
JZWIRKO is offline   Reply With Quote
Unread 05-18-2008, 06:10 PM   #2
Turbonut
Is what you're saying-when trying to tighten the nut, the ball is turning? Do the install and let the Jeep set on a loaded suspension, on all for wheels no jacks. That will place pressure on the ball and you'll be able to tighten the nut. Air rachet helps also.
Turbonut is offline   Reply With Quote
Unread 05-18-2008, 08:10 PM   #3
nashmd454
I had that problem too...I just cut them off and added some different one.http://www.energysuspension.com/pages/endl.html
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
[URL]http://photobucket.com/albums/v639/nashmd454[/URL]
[url]http://groups.jeepforum.com/The_Dark_Side[/url]
nashmd454 is offline   Reply With Quote
Unread 05-18-2008, 08:36 PM   #4
-Joe-
I would have bought some of this type..
http://cgi.ebay.com/ebaymotors/Sway-Bar-Links-Stabilizer-link-Jeep-CHEROKEE-Grand-Cher_W0QQcmdZViewItemQQcategoryZ33593QQihZ014QQite mZ7992644647QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/2-SWA...spagenameZWDVW
Ask for 94 or 95 endlinks, they have replaceable bushings, im sure they would still fit.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote
Unread 05-18-2008, 08:39 PM   #5
jeepheller98
some JKS discos cost like $20 more then dealer for 2 replacements..
anyway i would get some lock tight, put it on, and hit it with a impact gun, but just put the nut bearly on (so the treads start) that way when you hit it iwht the gun, the nut has a running start
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline   Reply With Quote
