Sway bar end connections crooked? - JeepForum.com
post #1 of 9 Old 07-18-2013, 04:16 PM Thread Starter
billyblooshoes
Something else caught me eye that doesn't quite look right. The joints where the sway bar connects on both sides looks crooked. What should I do to rectify this and what if anything will I notice as a result of this? Seems to be driving pretty good.
billyblooshoes is offline
post #2 of 9 Old 07-18-2013, 05:02 PM
newfieZJ
looks normal . it's a ball joint connection so it has movement
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 9 Old 07-18-2013, 05:51 PM
dnuccio
someone installed those endlinks wrong. theres supposed to be a rubber piece under the sway bar, and another one on top of the sway bar, then the nut goes on.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 9 Old 07-18-2013, 06:02 PM
newfieZJ
That applies to 93-95 , not 96-98
newfieZJ is offline
post #5 of 9 Old 07-18-2013, 06:25 PM
dnuccio
really? why would they be different?
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 9 Old 07-18-2013, 06:46 PM
newfieZJ
93-95 used as you described , bushings , washers and a nut . 96-98 uses a ball/socket type connection . Moog sells a greasable end link . From an engineering stand point , it's probably a better design .
newfieZJ is offline
post #7 of 9 Old 07-18-2013, 11:12 PM
dnuccio
huh thats interesting. could maybe be a cheap upgrade for 93-95 ZJs? wonder what the benefits would be other than being able to grease it
R.I.P. Ratmonkey
dnuccio is offline
post #8 of 9 Old 07-18-2013, 11:19 PM
MTBlue
100x better! I say from experience, the Moog end links work flawlessly. Not a squeak from the front end since I've installed them, and so far they haven't budged.
To the OP: Yes, that is normal, as Newfie said.
Dirt Deprived
MTBlue is offline
post #9 of 9 Old 07-18-2013, 11:50 PM
Uniblurb
Uniblurb's Avatar
Maybe they started the ball/socket sway bar links in 97 since my 96 ZJ and son's 96 XJ both came from the factory with the straight shaft link with a couple curves in it. We were breaking them left and right, not even off-road, and in going to the Moog's w/ball joint sure fixed that problem! Nice, they are greasable too as you mentioned.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is online now
