Sway bar adjustment? - JeepForum.com
post #1 of 4 Old 12-29-2004, 06:09 PM Thread Starter
TOM380
Is it neccesary to do any adjustments to the sway bar with a 2" BB?
My jeep seems to ride stiffer now with the BB, and no other mods.
1997 ZJ 5.2L V8,K&N AIR FILTER,FLO-MASTER EXHAUST 2"BB LIFT 30" REMINGTON WIDE BRUTES. ProComp ES3000 SHOCKS, CUSTOM SPARE TIRE CARRIER AND ROOF RACK,HELLA LIGHTS. JUST GETTING STARTED!!!!!
1968 Jeep (Kaiser) Wagoneer, Buick 350 V8, Isky cam,HEI ignition, TH400 trans and completly stock inside and out.
TOM380 is offline
post #2 of 4 Old 12-29-2004, 07:52 PM
jeepholic
jeepholic's Avatar
Not at all, you should be cool.
The only way the swaybar would effect stiffness is if it's getting pulled so hard that you would have had to fight it to get it on the discos in the first place, if you connected them, then it's not to tight.
If you did not change your shocks, then you pulled them out anoyther 2" from where they are used to be pulled out to, you are on the limit of needing extended shocks, if you did change them then you just bought stiff shocks. I would be happy, I am under the assumption my 2"BB made things feel a little more tipsy and I would have liked stiff, now when some when says they have stiff shocks, I like go with those.
Matter of taste, but my girlfriend is saying Stiff is better.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #3 of 4 Old 12-29-2004, 07:52 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
You shouldn't need to adjust the swaybar with only 2". All you really need to get is a front end alignment.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #4 of 4 Old 12-29-2004, 08:13 PM Thread Starter
TOM380
I got the alignment done already. And I did not replace the shocks yet. I am looking at the Pro Comp ES3000 4wheelparts has a special on 4 ES3000's and an ES2000 steering stabilizer for $125.00. I have 91k on my Jeep and I think the shocks are stock?
TOM380 is offline
WJ Caster Adjustment - ADJ CA ntaousakis ZJ Grand Cherokee Forum 8 06-13-2016 08:52 AM
seat adjustment frumpy ZJ Grand Cherokee Forum 9 05-11-2009 12:15 PM
VIC 242 adjustment Dillonzj ZJ Grand Cherokee Forum 2 08-06-2008 04:44 PM
Caster Adjustment 94 ZJ dpierson ZJ Grand Cherokee Forum 4 06-04-2007 12:39 PM
GC Tailgate Adjustment mhouston ZJ Grand Cherokee Forum 1 06-30-2004 12:48 PM
