Swapping tranny's in a 95 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Swapping tranny's in a 95
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 10-04-2009, 04:37 AM   #1
deancass2000
All, I'll try to make this short and sweet.....
I have 95 GC 4.0 manufactured date of 6/95 with fulltime 4wd 249 t-case, bad tranny. Stamp on bellhosing says "290-4"
I have a donor tranny from 95 GC 4.0 with manufactured date of 01/95 with a 242 t-case. Stamp on bellhousing says "290-1"
The only visible difference are the fittings on the tranny itself for the tranny fluid lines. I can swap those though.
Here is my question.......when I first looked up a tranny on car-part.com it said they were different for a 95. Showing tranny's up through 01/13/95 and then 01/14/95 and greater for the other one. Does this really matter? Are the tranny's the same electronically and maybe my difference is just the fittings? Also, I've read where I should have no problem swapping the tranny that had the 242 on it into my tranny with the 249, but if I went the other way I would have to swap input shafts.
Any input would be greatly appreciated.......
Thanks, Dean
deancass2000 is offline   Reply With Quote Quick reply to this message
Unread 10-04-2009, 08:01 AM   #2
ratmonkey
R.I.P.
ratmonkey's Avatar
the 249 case came with a long input for the 46rh and a medium input for the 42re. 242's in zjs came pretty much only with the medium input.
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 10-05-2009, 09:56 AM   #3
deancass2000
Anyone else have any input on the electronics of the transmissions? I'd like to gather as much information first before installing the new tranny.
