swapping tranny from 42re to aw4 - JeepForum.com
post #1 of 5 Old 10-04-2009, 11:22 AM Thread Starter
jeffp2152
No longer trying to swap, just trying to figure out what else I need to do besides change my transmission. read down thanks!
jeffp2152 is offline
post #2 of 5 Old 10-04-2009, 11:39 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
You don't have the wrong tranny.
AW4 was only used for the first couple months of production. Most 93s had 42re.
It's not just a matter of cooler lines and a couple sensors. The switch would require a LOT of wiring changes, and a different TCM (trans control module). You'd have to get a bunch of wiring out of an AW4 equipped ZJ, and plan on tearing apart most of the dash to do the job.
The TCM and wiring will cost more than the AW4 did, plus labor...
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 5 Old 10-04-2009, 10:37 PM Thread Starter
jeffp2152
ya you're right I forgot about the tranny computer. My 42re is messed up bad but I think I might have more problems that just the actual tranny. My o/d off switch used to work but now it doesn't. and in order to shift from drive to 2 while moving i have to apply the brake. so i think i might have some other problems going on too.
post #4 of 5 Old 10-05-2009, 12:49 AM
the88thpianoman
2003 WJ
Do you have an XJ cherokee like your deal says, or do you have a ZJ Grand Cherokee?
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #5 of 5 Old 10-05-2009, 05:37 AM Thread Starter
jeffp2152
its a zj sorry just changed it i didn't see the zj option on there the first time.
To sum my problems up:
-I know my current 42re is messed up because there are metal shavings in the trans pan. However, I am wondering if it is only the transmission that is messed up because of some random problems.
1. the o/d off switch no longer works. It did before the trans problems started.
2. the trans will not downshift at all and will not go into overdrive. will only go into 1 if i shift hard from neutral.
Swapping a 42RE automatic transmission for an AX-15 manual DelbertScholtes ZJ Grand Cherokee Forum 0 02-19-2009 07:16 PM
42RE Tranny ledfoot02 ZJ Grand Cherokee Forum 6 09-23-2008 07:43 AM
42RE tranny issue 4Slow9erHybrid ZJ Grand Cherokee Forum 8 05-29-2008 03:31 PM
another 42re tranny question? bikemanj7 ZJ Grand Cherokee Forum 6 01-13-2006 06:22 PM
42re tranny changes??? woodmanxxx ZJ Grand Cherokee Forum 0 09-09-2005 10:01 AM
