Swapping out D35 Axle - Page 2 - JeepForum.com
post #16 of 27 Old 09-01-2012, 06:46 PM
biggoofy
Most junk yards label the windshields with what's wrong.
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #17 of 27 Old 09-02-2012, 04:12 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
For just swapping axles I don't think you'll need any special tools,good breaker bar,hvy jackstands, good floor jack. Step by step in the fsm available online, on ebay,and other methods. Replacing the gear set or bearings is a bit more complicated,and alittle tedious. I had never touched one till the rebuild in my post. Its not impossible though and if you do your homework it'll be ok. I stayed with the d35 cause I putt from one location to another and it lasted all these years anyways.
Originally Posted by HighLonesome
coralman is offline
post #18 of 27 Old 09-02-2012, 07:41 AM
KingtheZJ
swap in a d44a. no questions that is the best option. especially since you have 3.73 already
http://www.jeepforum.com/forum/f13/w...-swap-1167646/
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #19 of 27 Old 09-02-2012, 08:34 AM
chevyblazer5150
The best way to remove old leaf spring U bolts is to cut through them with a hacksaw. Takes half the time of removing all 8 bolts. Just be sure you have a new blade and a spare just in case.
1995 Grand Cherokee Laredo, V8, 242 T-case swap, custom driveshafts, bumpers/rock sliders, X20 8000# winch, Rough country long arm kit w/5.5" rustys springs, full Detroit rear locker, HP D30/trutrack, 4:11 gears 32x11.5x15 Maxxis MT's
chevyblazer5150 is offline
post #20 of 27 Old 09-02-2012, 12:54 PM Thread Starter
Jimh64
Can I use the axles from my D35c in to the D44a?
Jimh64 is offline
post #21 of 27 Old 09-02-2012, 06:22 PM
PolkaPower
No.
Post number 8 http://www.jeepforum.com/forum/f13/d...a-axle-193889/
PolkaPower is offline
post #22 of 27 Old 09-02-2012, 07:29 PM
KingtheZJ
the main purpose of swapping to a 44a is the larger shafts. no, the 35 shafts wont work in the 44a.
'88 XJ
post #23 of 27 Old 09-02-2012, 07:46 PM Thread Starter
Jimh64
Since I just use it for a daily driver, no off roading, should I just stick with the d35? Or is there another benefit to the 44? I need the simplest and easiest.
Jimh64 is offline
post #24 of 27 Old 09-02-2012, 08:41 PM
iser
simplest and easiest: swap a d35 in. you don't need a 44.
- REST IN PEACE, RATMONKEY -
Specs- 97 ZJ 5.2L - 4" Zone Lift - 285/75R16 Cooper STT
Upcoming Projects- Front Axle Swap. On the look out for HP30.
_______________________________________________
"lead me, follow me or get the hell out of my way"
- gen. george patton
iser is offline
post #25 of 27 Old 02-06-2013, 06:45 AM
ahoyt653
swapping in a D44A, in to a 95 from a 96-98, will the drive shaft lengths be the same, I have got out to the junk yard yet to measure for myself?
ahoyt653 is offline
post #26 of 27 Old 02-06-2013, 07:06 AM
KingtheZJ
i cant five you a definitive answer. but there was some discussion here
'88 XJ
post #27 of 27 Old 02-06-2013, 07:43 AM
ahoyt653
Thanks I will have to look, 4.5" and I am at 4 so I might have to have it shorten, I will tested it out after the swap to see, thanks again
ahoyt653 is offline
swapping front axle yokes from a 93 to a 96, whats the torque? 89blkcomanche ZJ Grand Cherokee Forum 3 06-09-2010 09:24 PM
i'm swapping a 5.2 to 5.9, anything else i should do while its taken apart? snotrod ZJ Grand Cherokee Forum 3 03-13-2010 04:03 PM
Swapping in a 231 into a WJ GraKee99 ZJ Grand Cherokee Forum 3 04-15-2009 07:37 AM
Swapping D44a axles, anything funny about swapping their brakes? Jerry Bransford ZJ Grand Cherokee Forum 9 02-26-2009 08:40 AM
Swapping a 4.0 for a V8? Firegod14 ZJ Grand Cherokee Forum 53 03-29-2007 10:14 AM
