swapping input shafts - JeepForum.com
post #1 of 12 Old 09-24-2009, 01:45 PM Thread Starter
Inavacuum
Hey guys,
doing the 231 swap soon. The only thing I'm really worried about is swapping the input shafts. I'm planning on probably having to do that and I've read plenty of write ups but I've never seen anyone actually document swapping the inputs. If anybody could point me in the right direction, that would be awesome. I was told the gear cuts are the same. The donor is a 96 xj the Zj is a 95.
help?
95 ZJ 4.0 PART OUT: Silver Body; Grey Cloth interior
HPD30;RE BB w/ RE Shocks;KOR Rad Support
KOR XMember/TC Skid
Make an offer on anything you're interested in.
Inavacuum is offline
post #2 of 12 Old 09-24-2009, 04:22 PM
sandman
yes, gear pitch should be the same. you can just swap out the entire input shaft and sun gear and not even hassle with that part. once you get the t-case apart and remove all the snap rings it will all just slide apart. when i tackled mine i had nothing to go off of, i just started removing stuff and everything was self explanitory.
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 12 Old 09-24-2009, 06:12 PM Thread Starter
Inavacuum
Sun gear?
9 10
KOR XMember/TC Skid
post #4 of 12 Old 09-24-2009, 06:24 PM
sandman
the sun gear is what the input shaft mates up to.
the part on the far right next to the chain is the sun gear, you can see the input shaft sticking out of it. you can just swap over that whole unit, instead of splitting it to retriev the input shaft.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 12 Old 09-24-2009, 06:33 PM
Virmagicus
Virmagicus's Avatar
Ahhh, that main shaft looks a bit mangled.
Jeff
Virmagicus is offline
post #6 of 12 Old 09-24-2009, 06:35 PM Thread Starter
Inavacuum
when i split open the tcase, what will I need to remove to get to that?
KOR XMember/TC Skid
post #7 of 12 Old 09-24-2009, 06:37 PM
Virmagicus
Virmagicus's Avatar
Everything ... it's basically the last part.
Jeff
post #8 of 12 Old 09-24-2009, 06:58 PM
sandman
lol....the shaft was in good shape, what your seeing is white paint, dont ask me, it just had white paint on it for some reason.
1993 Jeep ZJ. 4.0
sandman is offline
post #9 of 12 Old 09-24-2009, 07:52 PM
Rmart30
Rmart30 is offline
post #10 of 12 Old 09-25-2009, 09:07 AM Thread Starter
Inavacuum
thanks guys.
why is the 242 swap so much more popular than the 231? From what I know, the 242 is weaker and doesn't have any aftermarket support like the 231 does.
KOR XMember/TC Skid
post #11 of 12 Old 09-25-2009, 09:19 AM
ZeJokee
Probably due to the 4at option.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #12 of 12 Old 09-25-2009, 12:15 PM
Rmart30
thanks guys.
The 4 wd full time option is what made me go with it. Even though the 242 is weaker than a 231 it will last forever with no problems for what most of us will be putting it thru. Ive only heard of 2 242's grenading .... and with those two people a 231 wouldnt have held up either with what they were doing.
Rmart30 is offline
249 to 242. didnt need to swap input shafts. anyone else? g2mike ZJ Grand Cherokee Forum 2 04-25-2009 08:19 PM
Swapping D44a axles, anything funny about swapping their brakes? Jerry Bransford ZJ Grand Cherokee Forum 9 02-26-2009 08:40 AM
ECU/PCM swapping ZJ Lee ZJ Grand Cherokee Forum 7 07-13-2007 07:23 AM
front zj u-joint axle shafts a direct swap for cv axle shafts? bjl95mustang ZJ Grand Cherokee Forum 12 05-19-2007 05:57 PM
Swapping a 4.0 for a V8? Firegod14 ZJ Grand Cherokee Forum 53 03-29-2007 10:14 AM
