swapping a grand cherokee rearend for a cherokee dana 44 is it strait bolt in - JeepForum.com
post #1 of 3 Old 11-01-2009, 09:00 PM Thread Starter
kojak70
my motor in my jeep wrangler that i drive now just went out so i found a grand cherokee that i can get really cheap but it needs a rearend i have a dana 44 that came out of a cherokee will it bolt straight up to the grand cherokee.
kojak70 is offline
post #2 of 3 Old 11-01-2009, 09:36 PM
Kramer H
Built and Supercharged 47
Kramer H's Avatar
so your looking to swap in a Cherokee d44 into the rear of your...wj? zj? there will be modifications involved. Cherokees used leaf springs, grands use coil springs, that's just the basics, then you will either need to weld on a rear track bar mount and control arm mounts if its a zj, or a stock 3 link setup and LCA mounts if its a wj. what year is your grand? just get a rear end out of a similar jeep. less of a headache and cheaper.
Built Beater 01 WJ
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Racefit,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, R&G Engineering, Two brothers, ASV, DDM, "The pantie dropper"
Kramer H is offline
post #3 of 3 Old 11-01-2009, 11:44 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
You'd need to weld on brackets. And be sure to get the right gear ratio.
ratmonkey is offline
01 grand cherokee Rearend locks up in 4wheel dive. Armadasx ZJ Grand Cherokee Forum 8 12-19-2008 07:57 AM
whats involved: swapping in a 231 t case for a 242 in a 94 Grand Cherokee? speedingpenguin ZJ Grand Cherokee Forum 12 06-05-2008 12:02 PM
94 grand cherokee rearend? capone518 ZJ Grand Cherokee Forum 13 03-07-2008 07:45 PM
Swapping a 4.7 HO into a 02 grand cherokee 4.7 spoochmlb ZJ Grand Cherokee Forum 15 02-06-2008 03:06 PM
99 grand cherokee rearend problem? wrangler512 WJ Grand Cherokee Forum 2 01-08-2004 01:25 PM
