swapping front axle yokes from a 93 to a 96, whats the torque? - JeepForum.com
post #1 of 4 Old 06-09-2010, 03:25 PM Thread Starter
89blkcomanche
so im swapping over to 3.73 gears on my 93zj so i had to find a front and rear diff, well the front diff i got was from a 96 and they changes the yoke style from the u joint style to the cv style, so im just going to swap the yokes from one to another, so what is the torque going to be on the nut because doesn't that change the bearing preload the more its torqed?
93' ZJ 4.0l 4x4 auto, trail rig, 6 kc's, green and gray, 3.73 swap, 32x11.50 bfg mudd terrain
89' comanche, 2.5L 80k original miles, single stage paint- sold
89blkcomanche is offline
post #2 of 4 Old 06-09-2010, 04:13 PM
WiCkeDuDe
WiCkeDuDe's Avatar
The way that the yoke is correctly tightened is to measure the bearing preload. There is not a set torque for the yoke nut itself.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #3 of 4 Old 06-09-2010, 05:16 PM Thread Starter
89blkcomanche
alright, so what would be the correct way of tightening it? am i going to have to remeasure bearing preload?
post #4 of 4 Old 06-09-2010, 09:24 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Unless you don't want to keep that gear set for long.
Remove everything from the axle including carrier. Mark the bearing caps for which side they go on.
Using a 0-75 or 100inlb torque wrench(any digital, dial or beam inlb wrench with single inlb markings will do) measure the torque required to rotate the pinion and record it.
Remove the pinion nut recording the torque required to break it free. You'll need a dial, or beam 250 ftlb wrench for that.
Put the new yoke and nut on tightened to 5ftlbs more than the previous nut and check rotating torque. Increase in 5ftlb increments till you get in spec without exceeding 275 ftlbs.
ratmonkey is offline
Swapping out cv front DS for U-joint DS 97DCZJ ZJ Grand Cherokee Forum 4 02-21-2010 09:19 AM
Front Axle Spindle Nut Torque Spec ajnolin ZJ Grand Cherokee Forum 2 01-07-2010 10:00 PM
replacing the front axle yoke...torque specs Travis873o ZJ Grand Cherokee Forum 10 10-16-2009 06:46 AM
Front driveshaft too long after swapping front differential jjeeeeppss ZJ Grand Cherokee Forum 11 08-12-2008 05:19 PM
whats involved: swapping in a 231 t case for a 242 in a 94 Grand Cherokee? speedingpenguin ZJ Grand Cherokee Forum 12 06-05-2008 12:02 PM
